+ Reply to Thread
Results 1 to 2 of 2
Thread: Detach and Re-Glue an Odom Deck
  1. #1
    Default Detach and Re-Glue an Odom Deck
    On my Odom, which is about 12 years old...
    Apparently, the builder of my Odom, used an inferior type of epoxy, that loosens when exposed to water. I have already re-glued the keel block and the two bulkheads using a marine-grade epoxy (from Home Depot) and now the deck has come off on the Stbd side so much that a piece of tape no longer keeps it from leaking.
    I need to to remove the entire deck. I think I will add some more wood strips on the edge, probably a 1/4 x 1/4 inch strip, for a bigger gluing surface. Then I would probably add a fillet to seal it from bilgewater.
    Some tips, other than to be very careful when cutting the seam would be appreciated, as well as any tips to re-glue the deck seam, as I would probably need to mix a large amount and spread it on. Can you brush it on, or is a spatula better? Wax and add a strip of masking tape to the outer hull to keep any epoxy from dripping?
    thx
    Sail honest.
    Rock music.
  2. #2
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,295
    Default Re: Detach and Re-Glue an Odom Deck
    Hi should not be too difficult with the use of a Dremel tool and circular saw blade so far no others parts are bonded under the deck. see sketch. On the Net I found this link plenty of good images : https://odomyachts.com/models/
    I suspect nevertheless, a big problem with several bonded parts. see page 33 of the "instructions manual".
    There is the external solution consisting on the bonding with epoxy a long corner glass fiber ribbon bent at 90 4x4mm or 5x5mm along the hull sheer line made with a previous made deck plywood mock up. You may adds later wooden stripes to mask the glass fiber. The deck mock up shall be covered with plastic film (garbage) to avoid glass corner bonding
    Good luck
ID:	16597   Click image for larger version
+ Reply to Thread
Similar Threads
  1. For Sale Odom
    By marcsmith in forum Classifieds
    Last Post: 09-23-2010, 06:55 AM
  2. Wanted Odom
    By stephanuccio in forum Classifieds
    Last Post: 05-26-2009, 06:03 PM
  3. Can I us CA glue for this
    By A.B. in forum General Discussion
    Last Post: 12-10-2007, 01:53 PM
  4. Glue for laminating veneers on hull
    By Mahoo in forum How To ?
    Last Post: 01-01-2007, 10:35 PM
  5. Glue you use
    By Albertaclipper in forum General Discussion
    Last Post: 05-19-2004, 12:04 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
