+ Reply to Thread
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Thread: Alpha Sabre - 3D performance
  1. #11
    Join Date
    Nov 2004
    Location
    New Hampshire, USA
    Posts
    924
    Default Re: Alpha Sabre - 3D performance
    Claudio, I agree with your opinion of Brad's sailing skills. But I also think he is one of the best designers around, and the track record of the Britpop in the hands of other skippers seems to validate the design.
  2. #12
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,289
    IOM is almost a monotype design since the only free parameter is the Beam and as such his contribution to winning potential as 'system boat' is low.
    When at a racing event out of 30 boats, 15 are BP, the chances to win is rather high. Fashion effect as always !!!.
    There is very little that can be done on a IOM design to make it superior above others IOM except Rig adjustment, Sail quality.
    Interesting to note that often the successful skippers are also Sail Manufacturers.
  3. #13
    Join Date
    Nov 2004
    Location
    New Hampshire, USA
    Posts
    924
    So then, Claudio, how would you explain the success of his M and 10R designs? Just his sailing skills?
  4. #14
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,289
    Gold Fingers and Weather conditions understanding !
    Like in Formula One, all cars are very close in performances, same power, same tires, but the winning is shared by one or two drivers out of 30.
    Are you prepared to win the next World Championship with the BP ?
  5. #15
    Join Date
    Nov 2004
    Location
    New Hampshire, USA
    Posts
    924
    Are there other designers that you respect, Claudio?
  6. #16
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,289
    Naval Architects !
  7. #17
    Join Date
    Aug 2003
    Location
    Logan, UT
    Posts
    182
    Quote Originally Posted by claudio View Post
    Claudio, the second part is a extremely simplistic statement, there is definitely more than sails and rig adjustment in IOM design/development. There is a lot that can be done to improve an IOM performance, otherwise we would not have seen so many designs disappear from regattas .......
  8. #18
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,289
    Gio,
    the IOM success is due essentially to economical issue derived by the material constraints.
    I do not see what can be done to improve performances above the existing ones.
    Sail Area/Mast height are blocked, Displacement is blocked, Draft is blocked, Keel is blocked...!!
    Left free beam and colors and 3D to help reducing costs
  9. #19
    Join Date
    Aug 2003
    Location
    Logan, UT
    Posts
    182
    Well, without going into the class rule reasoning and idea, yes, a lot of parameters in the IOM are fixed (rig) or have max and min tolerances (hull, appendages), but there is still a lot that can be shifted and moved around to improve performances independently of the rig .... and a lot that can be done to mess the boat up to. Just look at the foil development during the years, or boat balance, or even sail development all done within the constrains of very strict rules (no one will still use a 10 years old keel and claim that it performs better in terms of lift and drag than a brand new creed keel .... ).
    You mentioned Brad, and beside being an incredible sailor/builder and designer, he is been also working on improving the performances of older boats (M and IOM) and just by updating the foils and little less he could make an old windstar perform better and by small hull modifications, re-balancing the hull and new sails, make it actually sail well at a club level, and we are taking about a hull that no one in his right mind would have even sailed when it came out ....
    yes the are limitations in the IOM rules, but there is ample play within the rules to play/improve performace and boat design, and while 3D printing will most likly not be the future of RC sailing, its definitely a powerful tool that can help in boat design and development, potentially you can modify and play with your hull and have a prototype in the water (sailing) within a day or two ..... and that's a quite somenthing .....
  10. #20
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,289
    Gio,
    You mix up too many things.
    Tell us what can be changed to IOM to improve the performances, since this was the subject. I'm sure Brad and others will be glad to hear about....
+ Reply to Thread
Similar Threads
  1. 3D Footy performance
    By mudhenk27 in forum General Discussion (Footy)
    Last Post: 07-02-2017, 02:36 AM
  2. FOOTY Performance.
    By IanHB in forum General Discussion (Footy)
    Last Post: 03-21-2007, 09:08 AM
  3. Footy Performance
    Last Post: 03-04-2006, 06:36 PM
  4. us one meter performance
    By express27 in forum General Discussion
    Last Post: 07-05-2005, 01:25 PM
  5. BAOW Performance Number
    By Dick Lemke in forum General Discussions (MultiHull/MultiOne)
    Last Post: 04-20-2004, 10:24 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
