+ Reply to Thread
Page 4 of 4 FirstFirst ... 234
Results 31 to 40 of 40
Thread: MICROMAGIC vs NANO
  1. #31
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Default Re: MICROMAGIC vs NANO
    Quote Originally Posted by mudhenk27 View Post
    Claudio, are you sure you aren't being too conservative? My Footy A rig (based on Claudio Vigada's Easy Rig III) is 1910cm2. I'm sure won't stand up in 12kts, but I don't see why it would have to.
    Not my fault if Bernoulli did not considered Footy in a protected environment !
    My static calculations are simply based on the Bernoulli law application and, of course, conservative by definition.
    see: https://www.theamya.org/sails/146_SailsPart2.pdf
  2. #32
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    A review of the static Footy sailing conditions with a bulb of about 300g and 1.9dm² of sail area, the calculations reveal that with a Wind of 2.5m/s the tilt = 30° and with 3.0m/s the tilt = 45°.
    Tolerated +10% Wind Speed when CE below 50/60cm from water.
  3. #33
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Here the PICO 1200 cm² Sail Plan
    Swing Rig A
    Main Luff 850mm
    Jib at 22%
  4. #34
    Join Date
    Nov 2004
    Location
    New Hampshire, USA
    Posts
    926
    Claudio, I've never measured the wind speed for my Fooy, but your calculation seems to be in the ballpark.
  5. #35
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    In this game it is difficult to be more precise since a boat is not like a car driving on a solid element.
    2 out of 3 elements cannot be scaled and their implications predominates more and more as the boat get smaller.
    An interesting book: "The Forgotten Factor" of CA Marchaj
    Here what I consider a pleasant sailing with smooth maneuvers with the AC100 and RG65 and 3 kt of wind and calm environment:
    https://youtu.be/R4MM_z_q3aI
    I think is time for me to go back to my Class M "1290"...
  6. #36
    Join Date
    Nov 2010
    Location
    Johannesburg
    Posts
    252
    Speaking of car analogies (which is what I always use because I'm more comfortable with them) I had a penny drop yesterday.
    I have been thinking of the sail plans as the "engine" of the boat.
    bigger sailplan = more power.
    Correct me if I'm not mistaken, but the wind is the engine, not the sailplan.
    The sailplan would be the gear box.
    WRT the Pico, If you have can give/upload the stations I'll build it in CAD and upload the STL/OBJ files for anyone wanting to try print them.
    Bill also kindly supplied me with his IGES file that I've been playing with. I've successfully converted it into an STL and with his blessing I can also upload that..... I'll post in the "New class" thread
  7. #37
    Join Date
    Nov 2004
    Location
    New Hampshire, USA
    Posts
    926
    Andrew, I'd appreciate your waiting just a bit. While I'm confident that my Nano will sail well, I've never been comfortable with releasing plans to the general public before they are fully tested on the water. There are a couple of them being built as we speak, so it shouldn't be too long. Once some testing is done, and any resulting tweaks made, then I'll make sure you get a new file that you can release it wherever you want.
    Thanks.......Bill
  8. #38
    Join Date
    Nov 2010
    Location
    Johannesburg
    Posts
    252
    Of course
    Sorry, I just get carried away lol.
  9. #39
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Hi Andrews,
    PICO is a difficult model that personally I will not build, since I prefer bigger models !!!
    Free plan, in attachment see PDF files of PICO-1C.
    Shadows are at scale 1:1.
    My worries remains with the construction weight that is actually limited to 233g.
    Servo Arm not useful unless positioned far away from LCB. Drum servo retained but the weight is 45g already.
    Swing Rig retained since lighter.
    Overweight will move up the floating line, may be still acceptable if limited to 1-2mm max since the LWL is of 480mm.
    Attached Files Attached Files
  10. #40
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Just elaborated the 3 swing rigs A, B and C. As said before the swing rig at this size level is lighter because Stays, Shrouds, Spreaders,Turnbuckles and supports are absent. For those more interested about Swing Rig see : Ivor Bittle website "the RC Racing Yacht Explained" 'Chapter 10' : http://www.ivorbittle.co.uk/
+ Reply to Thread
Similar Threads
  1. Announcing the exciting new NANO class
    By mudhenk27 in forum New Classes
    Last Post: 07-24-2017, 06:04 AM
  2. RG65 MicroMagic
    By martin in forum General Discussion (RG65)
    Last Post: 07-22-2009, 02:08 PM
  3. MicroMagic fun and LOTS of noobies questionS
    By wismerhell in forum General Discussion
    Last Post: 07-27-2005, 04:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
