+ Reply to Thread
Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
Thread: Esterel 45
  1. #21
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Default Re: Esterel 45
    Bonding process continue...
    Only the central beam is bonding, while leading and trailing edges will be bonded later.
    The weight is very close to 130g ! Hope the strength will be also there !
    Part of the aluminum trailing edge will be removed and a hard wood leading edge will be probably added.
    According to my records, the epoxy resin weight used up to now is 17g.
    Actual weight 126g before leading and trailing edges bonding, therefore the total epoxy resin used so far is 20g.
ID:	16481   Click image for larger version
ID:	16482   Click image for larger version
ID:	16483   Click image for larger version
ID:	16484   Click image for larger version
  2. #22
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Keeping my fingers crossed while carbon-carbon Fin is under bonding process, I drawn a possible back up using a classic construction method similar to the one I used before.
    This is what I have found ...
    of course the tissue will be crossed 0 -45.
  3. #23
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Revisiting the Balsa Fin Design some width dimensional data are changed because of the Carbon Skin thickness that modify the end product dimensions.
    Generally I use to make the Appendage's Areas equivalent to 6/6.5% of Sail Area.
    Taking an average Sail Area of 7300cm, the Appendages areas may vary from 438cm and 474cm. The Fin will use 3/4 of that area = 328cm to 355cm
    Taking into account final dimension, I reduced the balsa width dimensions. See Profiles.
    Since I do have introduced a 4x4mm square tube as well the 4mm brass rod the fin thickness will be constant from top to bottom and by consequence the profile thickness will change from 6.2 at the Top to 7.0% at the Bottom.
    Meanwhile the Trailing Edge on the Full Carbon Fin is bonded and Leading edge under way.
    I think the Final Carbon Fin will be some few grams above the expected weight. Off course the trimming of aluminum trailing edge will partially compensate.
Name:	Balsa FIN profile.jpg‎
ID:	16487   Click image for larger version
ID:	16488   Click image for larger version
ID:	16489   Click image for larger version
  4. #24
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Balsa Fin preparation ...
ID:	16491   Click image for larger version
  5. #25
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    A Bad News that become a Good News !!! While I was cutting the Aluminum stripe excess a strange noise pop up indicating local dis-bonding. Decision taken : Remove the aluminum stripe all together, removing at the same time the risk of cutting my fingers when manipulating around the trailing edge and at the same time reducing the Fin Weight !!!....
    I'm getting old and forgetting some tricks, in the past the "123" Fin was made by using an Aluminum stripe plenty of holes to ensure better bonding !!!
    After discussion with my friend Mechanical Engineer, I decided to let thinks as they are, further a sharp truncated trailing edge of 1mm of thickness appears to be more efficient hydro dynamically.
ID:	16493   Click image for larger version
ID:	16495   Click image for larger version
Name:	Fox & Grapes.jpg‎
  6. #26
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    The Aluminum stripe is replaced by epoxy resin as in the picture.
    Actually the Fin appears very stiff, but test with 3.0kg bulb will be made at the end of next week and not before.
Name:	Epoxy trailing.jpg‎
ID:	16496   Click image for larger version
  7. #27
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    For the Balsa-Carbon Fin I changed my mind, instead of one carbon square tube I introduced two carbon carbon tubes. Don't ask me why, just a guess for strength. Full Carbon Fin is "resting" waiting for total polymerization (one week).
ID:	16501   Click image for larger version
ID:	16502   Click image for larger version
Name:	Fin prof 2.jpg‎
  8. #28
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Basic Fin components are bonded except the leading edge.
    Only one face sanded.
    Actual weight 70g, this include the addition of Leading Edge carbon Rod and epoxy resin used for bonding.
ID:	16504   Click image for larger version
ID:	16505   Click image for larger version
  9. #29
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Standby for a while due to annual shops holiday.
    Missing carbon tissue
    Wood plates for clamp
    Soft foam
    Carbon Fin bending test with 3kg bulb will be carried out this week according to that setting :
Name:	Fin Test.jpg‎
  10. #30
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    As planned, today after 9 days from assembly, I have performed the 'bending test' of the carbon Fin with the 3Kg Bulb.
    The results are not the ones I would have hoped, but still inside for a future use.
    With a 5.5mm thick Fin is probably the max I could achieve.
    5.5mm / 80mm chord = 6.8% thus better than 7% if all that has some meaning for our models.
    Of course under water the 3.0kg Bulb will become 2.72kg and the Fin will bent less..!
    These are all excuses to justify the Fin use !!!!
    No shape hysteresis noted.
    The test will be repeated next WE when the polymerization will be more mature.
ID:	16508   Click image for larger version
ID:	16509   Click image for larger version
ID:	16510   Click image for larger version
ID:	16511   Click image for larger version
+ Reply to Thread
Similar Threads
  1. Esterel footy
    By claudio in forum General Discussion (Footy)
    Last Post: 07-30-2015, 07:28 PM
  2. Free ESTEREL M - Ruby-RV
    By claudio in forum Designs And Plans
    Last Post: 05-13-2014, 07:00 PM
  3. 1.2.3. Esterel-2
    By claudio in forum New Classes
    Last Post: 01-08-2014, 08:56 PM
  4. 1.2.3. - "esterel"
    Last Post: 11-05-2012, 06:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
