+ Reply to Thread
Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 56
Thread: "1290" Class M Hard Multi Chine Hull
  1. #41
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,137
    Default Re: "1290" Class M Hard Multi Chine Hull
    Before fixing the shadows it is necessary to laminate the trunk effort areas as the Rudder, Fin/Mast and Jib.
    Glass fiber 162g/m - added expected weight 65g
ID:	16141   Click image for larger version
ID:	16142   Click image for larger version
ID:	16143   Click image for larger version
  2. #42
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,137
    While waiting for a complete polymerization of previous work, I started building the mock-up for the Peaked Deck.
    Simple shape, but not easy to make unless I'm loosing my manual capacity...!! nevertheless it will look like this picture...
    Later as usual...sanding and packing tape...
  3. #43
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,137
    Since stern and bow are sealed, was a good opportunity the fill the hull with water. I used a blue pigment to get a better view although not very impressive. Filled 4085cm3 of water which is a little bit more then the 4023cm3 as per design. Considering that this volume is based upon the internal hull form, no problems. All in line with the design except that a couple of leaks are found. (second purpose to fill in water)
ID:	16147   Click image for larger version
ID:	16148   Click image for larger version
ID:	16149   Click image for larger version
ID:	16152   Click image for larger version
  4. #44
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,137
    Peaked Deck under lamination with two layers of 80g/m glass/epoxy and hull weight check. Measured 369g a bit too much, but I need checking.
ID:	16159   Click image for larger version
ID:	16160   Click image for larger version
ID:	16161   Click image for larger version
  5. #45
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,137
    After cutting the deck template and repositioned the peaked deck I found that is not looking nice to my view. For me is too wide. A new one is ongoing !
    Fin top modified and threaded rod integrated with bolts. Tomorrow the bonding with loaded epoxy !
ID:	16166   Click image for larger version
ID:	16167   Click image for larger version
ID:	16168   Click image for larger version
  6. #46
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,137
    Work progressing around the new Peaked Deck and Fin.
    Bottom side of the Fin modified to allow matching with bulb shape at 2 tilt. Preparing for fairing.
    Top side Brass Rod bonded with loaded epoxy.
    Peaked Deck mock up preparation is requiring more time then expected since I desire to integrate a stepping wedge to met the deck bonding.
    Mock up bonded with vinyl glue (for wood) on a piece of Polystyrene Foam for easy handling.
ID:	16183   Click image for larger version
ID:	16184   Click image for larger version
ID:	16185   Click image for larger version
  7. #47
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,137
    Peaked Deck master ready for lamination
ID:	16187   Click image for larger version
ID:	16188   Click image for larger version
  8. #48
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,137
    This morning I wake up with the idea to cut out the slot for the Fin Trunk.
    Later I will try to spray the white primer first layer if temperature in garage is OK.
    Having removed the hull from the support after several days I noticed how much the hull is sturdy.
    I could have gained about 50g using 2 layers instead of 3.
    The actual thickness at the hull bottom around the trunk area reinforcement is of 0.9/1.0mm and this is due to : 3 layers of Glass tissue of 80g/m for the hull + 2 layers of glass of 160g/m around the Fin Trunk area. Final slot dimension 70mm x 13mm
ID:	16195   Click image for larger version
ID:	16196   Click image for larger version
ID:	16197   Click image for larger version
  9. #49
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,137
    This afternoon I finally went to the garage with 16C, but found on the spray can that the accepted temperature range is 10C to 32C.
    2 layers of Primer at interval of 1/2 hour and the 3rd layer after 1 hour.
    Weight increased only 16g.
    Some pictures below.
ID:	16200   Click image for larger version
ID:	16201   Click image for larger version
ID:	16202   Click image for larger version
  10. #50
    Join Date
    Jun 2012
    Location
    Portland, Tennessee, USA
    Posts
    16
    Claudio,
    The chine hull reminds me of a boat that I used to watch occasionally off Southern California many years ago.. It was named "Rag Time" and was a winner in the Trans Pacific race to Hawaii at the time.
    I'll bet that this boat will be fast too; it certainly looks it. You're going to have to paint it "swirl" to keep other skippers from seeing the fast lines of this hull.
    Have you decided on a name?
    Can't wait to hear how quick she is, hopefully she will be a winner on the racing scene.
    Clark
+ Reply to Thread
Similar Threads
  1. Free "1290" a New Class M
    By claudio in forum Designs And Plans
    Last Post: 12-16-2016, 09:52 AM
  2. Water inside my "Sealed" hull
    By Tom the Brat in forum New Boat Owners
    Last Post: 04-08-2012, 12:07 PM
  3. New mixed class "Racing formula 100R"
    By K1W120 in forum New Classes
    Last Post: 02-11-2012, 01:17 PM
  4. How the development of "Nightmare Mk.VII+Mk.VIII" leaded to "Mk.IX+ Mk.X"!
    By disabled in forum General Discussions (MultiHull/MultiOne)
    Last Post: 03-06-2011, 11:27 AM
  5. Using Hulls to build a hard chine hull
    By Muzza in forum General Discussion
    Last Post: 01-05-2006, 12:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
