+ Reply to Thread
Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 87
Thread: "1290" Class M Hard Multi Chine Hull
  1. #21
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Default Re: "1290" Class M Hard Multi Chine Hull
    Sanding of plug completed.
    A lot of very fine dust, hope the vacuum cleaner will not suffer too much !!
    Cleaning with dry tissue only. No water !
    Next, coverage with packing tape.
ID:	16066   Click image for larger version
  2. #22
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Packing tape applied, one layer only.
ID:	16067   Click image for larger version
ID:	16068   Click image for larger version
  3. #23
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    While waiting for better weather conditions, lower RH, here a 'dual table' about Sail's & Rig Data used for a Class M model.
Name:	M - Sail's Data.jpg‎
  4. #24
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Before lamination and for precautionary reasons, I have applied two layers of Wax.
    Today I manage to laminate "Wet on Wet" 3 glass - epoxy layers.
    1 of 85g/mē
    2 of 105g/mē.
    Notice the second layers just laying on previous laminated one of 85g/mē without adding any epoxy.
    The 2nd layer is acting as a sponge absorbing the excess of resin like a "peel-off" tissue.
    No need to add too much resin, just what it is needed to cover the full surface.
    This is the way I use to keep the overall weight inside the rule of thumb : 50/50.
    Similarly for the 3rd layer.
    According to my calculations the hull surface is of 40.50dmē, therefore :
    (0.85g/dmē + 1.05g/dmē + 1.05g/dmē) x 2 for resin = 5.9g/dmē x 40.50dmē of hull = 238.95g .
    238.95g is the expected weight of the bare hull out of mold.
ID:	16071   Click image for larger version
ID:	16072   Click image for larger version
ID:	16073   Click image for larger version
  5. #25
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Removed the excess of glass-epoxy and let now cooking under the sun !!! Close to the Canal du Midi (construction 1666- 1681), and for those who like to knows more : https://en.wikipedia.org/wiki/Canal_du_Midi
ID:	16075   Click image for larger version
  6. #26
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    the Sun is gone and cloudy and windy again !!
    Although only 24h are gone, being impatient, I decided to de-mold the hull with the help of tiny fiberglass blades and hull got away without problems.
    The Master is still perfect !
    The bare hull weight is 259g instead of 238.95g. Too much resin ? Probably yes but less then the budget allocation !
    Now is arrived the moment to draw and cut the hollow shadows to allow hull "setup" assembly.
ID:	16077   Click image for larger version
ID:	16078   Click image for larger version
ID:	16079   Click image for larger version
ID:	16080   Click image for larger version
  7. #27
    Join Date
    Jun 2012
    Location
    Portland, Tennessee, USA
    Posts
    21
    Claudio,
    Coming along quite nicely. Looking good!
    Seeing your work makes one want to start another boat project.
    Clark
  8. #28
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Hi Clark,
    apparently I'm progressing without troubles except weather conditions.
    Also happy that the balsa mold came out in perfect shape, there was some fear at the begin.
    The basic idea to post my "build logs" is to let others to do similar things.
    My work is often an experimental one. If the results are good then I can think about a racing model of the kind.
    After reading some papers about the performances of a Chine Hull, I decided to make one model to verify what learn.
    In the past I did the "Delta Rig" based on 4 panels, a way to make a hull rapidly since the hull was not my major concern at that time.
    Today I have chosen a 6 panels Chine Hull after various considerations, in spite of the difficulties to draw a 6 panels hull, that may also explain why there are only few around.
    At the begin I drawn the 5 panels and 6 panels Hulls and the choice finally was for a 6 panels.
    The attached figure will probably explain why.
    In others words, it my understanding is that the 6 panels hull may have some advantages over the 5 panels.
    Above 6 panels the hull is getting close to a round hull and probably some chine hull peculiarities are lost.
    Since sensitive to the hull draft, the 6 panel is offering the lowest value as well a flat panel during low heeling conditions.
    A long flat surface may offer a better lifting like a surf.
    Further, the 6 panels exhibit larger surface orientation angles that could better acts as an anti-drift hull.
    Of course all that it is simply my opinion and the way I look at, nevertheless open to any other points of view.
    Hollow Shadows are drawn and ready for cutting
ID:	16083   Click image for larger version
  9. #29
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    I forgot to consider the thickness of the lamination (about 0.55mm) and now I have to rectify the shadows one by one !!!
    Only 3 made so far....
  10. #30
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    As per today ! not very satisfied of the hollow shadow cutting and the manual remedy rather boring. Shimming will be necessary in many places. The important matter now is to ensure that the beam width at each station is the one drawn. Because of the chine form, the edges/corners will ensure the hull form stability.
ID:	16090   Click image for larger version
ID:	16089   Click image for larger version
ID:	16088   Click image for larger version
+ Reply to Thread
Similar Threads
  1. Free "1290" a New Class M
    By claudio in forum Designs And Plans
    Last Post: 12-16-2016, 10:52 AM
  2. Water inside my "Sealed" hull
    By Tom the Brat in forum New Boat Owners
    Last Post: 04-08-2012, 01:07 PM
  3. New mixed class "Racing formula 100R"
    By K1W120 in forum New Classes
    Last Post: 02-11-2012, 02:17 PM
  4. How the development of "Nightmare Mk.VII+Mk.VIII" leaded to "Mk.IX+ Mk.X"!
    By disabled in forum General Discussions (MultiHull/MultiOne)
    Last Post: 03-06-2011, 12:27 PM
  5. Using Hulls to build a hard chine hull
    By Muzza in forum General Discussion
    Last Post: 01-05-2006, 01:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
