+ Reply to Thread
Page 2 of 9 FirstFirst 1234 ... LastLast
Results 11 to 20 of 87
Thread: "1290" Class M Hard Multi Chine Hull
  1. #11
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,296
    Default Re: "1290" Class M Hard Multi Chine Hull
    Further work with filler the same used to repair plaster wall. Easy sanding !
    Some additional images showing the bow problem ! Regularity of shape profile, similarly will be done on other chine corners although eyes view will be sufficient !
ID:	16000   Click image for larger version
ID:	16001   Click image for larger version
ID:	16002   Click image for larger version
  2. #12
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,296
    Progressing, rocker rectified, general sanding, support legs added, fiberglass 85g/m tissue precut.
    Legs needed to keep the hull above the plan to allow fiberglass epoxy lamination without interferences.
    see pictures :
ID:	16006   Click image for larger version
ID:	16004   Click image for larger version
ID:	16005   Click image for larger version
ID:	16007   Click image for larger version
  3. #13
    Join Date
    Jun 2012
    Location
    Portland, Tennessee, USA
    Posts
    21
    Coming along nicely Claudio.
    Some questions occurring to me when i look at the reverse sheer of the hull shape:
    I was wondering if you were going to split the hull in half in order to remove the fiberglass epoxy lamination from the mold? Perhaps because of the thin hull surface you will be able to “flex” the hull off the mold? Perhaps the reverse sheer is not as pronounced as it looks? Or maybe you’re just going to tear up the mold in the process of removing the laminated hull?
    Watching your progress with enjoyment.
    Clark
  4. #14
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,296
    Hi Clark,
    the reverse sheer is not very important it should not present problems. The fiberglass blades will help a lot.
    So tomorrow I will laminate the mold. 24hours later defect correction if needed.
    Once the mold is ready I will start the hull lamination with 3 layers of fiberglass of 85g/m.
    During polymerization I will cut the female shadows at 11, 9, 7, 5, 3, and A positions used as hull support.
  5. #15
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,296
    Two days of heavy rain and RH above 80%, thus no lamination until this morning.
ID:	16013   Click image for larger version
ID:	16014   Click image for larger version
  6. #16
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,296
    External lamination completed, today internal brushing with Epoxy resin...50 pictures up to now !
    Next I will use spray primer and soft sanding to remove tissue rugosity before applying packing tape.
    The white small pots filled with lead shots are used to keep the hull standing-up vertically
ID:	16019   Click image for larger version
ID:	16020   Click image for larger version
ID:	16021   Click image for larger version
ID:	16022   Click image for larger version
  7. #17
    Join Date
    Aug 2003
    Location
    Minnesota USA
    Posts
    3,811
    Hi Claudio -
    will all of those ribs/stations stay in place when done, or is there a plan to remove them. Obviously if using as a plug to layup plain glass hulls, there is no need to lighten the weigh of the plug.
    Nice job - looks great.
  8. #18
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,296
    Hi Dick,
    all the remaining parts of the shadows remain in place, no need to remove them since participating to the strength of the plug.
  9. #19
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,296
    Surface filler all over the glass coated hull.
    Only for dry conditions, no water.
    This filler is easy to sand and used to remove rugosity before applying packing tape.
ID:	16024   Click image for larger version
ID:	16025   Click image for larger version
  10. #20
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,296
    My preferred activity : sanding !!!
ID:	16027   Click image for larger version
ID:	16028   Click image for larger version
ID:	16029   Click image for larger version
ID:	16030   Click image for larger version
+ Reply to Thread
Similar Threads
  1. Free "1290" a New Class M
    By claudio in forum Designs And Plans
    Last Post: 12-16-2016, 10:52 AM
  2. Water inside my "Sealed" hull
    By Tom the Brat in forum New Boat Owners
    Last Post: 04-08-2012, 01:07 PM
  3. New mixed class "Racing formula 100R"
    By K1W120 in forum New Classes
    Last Post: 02-11-2012, 02:17 PM
  4. How the development of "Nightmare Mk.VII+Mk.VIII" leaded to "Mk.IX+ Mk.X"!
    By disabled in forum General Discussions (MultiHull/MultiOne)
    Last Post: 03-06-2011, 12:27 PM
  5. Using Hulls to build a hard chine hull
    By Muzza in forum General Discussion
    Last Post: 01-05-2006, 01:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
