+ Reply to Thread
Page 1 of 9 123 ... LastLast
Results 1 to 10 of 87
Thread: "1290" Class M Hard Multi Chine Hull
  1. #1
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,297
    Default "1290" Class M Hard Multi Chine Hull
    The Springtime is coming !
    Is time for me to return to the Models construction after almost 1 year stoppage due to recovery from hernia operation.
    A lot of thinking and discussions about pros and cons for hard chine hull performances.
    I just drawn a new plan for a Class M and there is only one way to verify it.
    Here the picture about.
    Among this design, it happen to discover various painting decorations methods, like "stretch adhesive film" often used for car body, "Hydrographical paint" with plenty of subjects and "Swirling paint", my preferred.
    On You Tube plenty of demonstrations simply using above key words.
    The M picture is the result of a screen shot made on one of YouTube short film.
    Just a link out of many : https://youtu.be/nAmvavELsFw
Name:	M-Chine 5P 0.jpg‎
  2. #2
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,297
    Default Re: "1290" Class M Hard Multi Chine Hull
    It may be of interest to watch this video : https://youtu.be/_CA0DR4GSQg.
    I will build my basin with glass-epoxy 150/160x50x50cm to dip the M hull
  3. #3
    Join Date
    Jun 2012
    Location
    Portland, Tennessee, USA
    Posts
    21
    What a fantastic way to paint a hull. Will look forward to seeing your progress with this concept.
    Of course you do realize that there may be many model boat builders that will now get their hands dirty with "swirl". LOL
    Glad to see you active again Claudio, I missed seeing your drawing and building activities.
    Clark
  4. #4
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,297
    Hi Clark,
    I'm just designing a basin support box that can be dismounted with the use a swim pool film. Unfortunately living in a flat I'd chosen the shower and missed the bathtub. Easy to put it back to the garage when not needed.
    Booth methods are interesting when I refers to Hydrographic painting and Swirling painting.
    For what concern the Class M model I changed from 5 to 6 panels chines because the draft and beam are smaller at 30 of heeling.
    BTW, the Hull Wet Area is very close to the one with round Hull.
    Expected more stability.
    Another simulation of swirling paint
Name:	Hardchine M 6Panels.jpg‎
  5. #5
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,297
    Six panels chine shadows are cut and ready to be fasten with samba stringers
ID:	15973   Click image for larger version
  6. #6
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,297
    Progressing with the template drawings in order to cut panels and successive bonding.
ID:	15976   Click image for larger version
ID:	15977   Click image for larger version
  7. #7
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,297
    Additional pictures as per today.
    Not happy with the bow area, some rework could be necessary.
    Samba stringers used to better protect the balsa sheeting corners.
    Next sanding work and filler before coating with Glass/Epoxy for reinforcement. Similarly the inner side between shadows.
ID:	15982   Click image for larger version
ID:	15983   Click image for larger version
ID:	15984   Click image for larger version
ID:	15985   Click image for larger version
  8. #8
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,297
    Hard rain and wind outside !
    Sanding stringers taking care around the chines corners in order to keep the smooth and linear profiles on booth side for symmetry. Not easy job !
    Some believe that hard chine hull are easy to develop, I can tell that is not true starting with the drawing plan and search of developed surfaces.
    Interesting to note that the minimum draft is obtained at 12.5 with 42mm and flat bottom.
    Next I need the soft filler to repair some defects close to the bow area. This mini problem is due to the fact that I used balsa sheets of 3mm thick where the widths close the bow are rather stiff. Employed 3mm balsa to avoid flexibility between shadows separated by 121.5 mm, but not always it help...
    Next time I will use plain balsa bloc and shaped.
    Last pictures below.
Name:	M-chine 6 F.jpg‎
ID:	15994   Click image for larger version
ID:	15995   Click image for larger version
ID:	15996   Click image for larger version
ID:	15997   Click image for larger version
  9. #9
    Join Date
    Jun 2012
    Location
    Posts
    21
    Smile Re: "1290" Class M Hard Multi Chine Hull
    Its soooooo! good to see you back at designing and building.
    I look forward to your posts because your explanations and illustrations are different than most. Your excitement shows through your excellent knack for photographing your work. I have, in the past had a photography business and was from young age very interested in the art of photography, so I think I know great work when I see it. Believe me, your photography of the projects you work on is on par with your design expertise.
    Keep up the exciting work and the sharing with us your passion for designing and building RC sailing models.
    Sincerely,
    Clark
  10. #10
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,297
    Very kind of you Clark.
    In the past I was very keen to use my camera.
    I'm of the opinion that a clean drawing and an image are replacing 1000 words !
+ Reply to Thread
Similar Threads
  1. Free "1290" a New Class M
    By claudio in forum Designs And Plans
    Last Post: 12-16-2016, 10:52 AM
  2. Water inside my "Sealed" hull
    By Tom the Brat in forum New Boat Owners
    Last Post: 04-08-2012, 01:07 PM
  3. New mixed class "Racing formula 100R"
    By K1W120 in forum New Classes
    Last Post: 02-11-2012, 02:17 PM
  4. How the development of "Nightmare Mk.VII+Mk.VIII" leaded to "Mk.IX+ Mk.X"!
    By disabled in forum General Discussions (MultiHull/MultiOne)
    Last Post: 03-06-2011, 12:27 PM
  5. Using Hulls to build a hard chine hull
    By Muzza in forum General Discussion
    Last Post: 01-05-2006, 01:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
