+ Reply to Thread
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Cinco De mayo Regatta
  1. #1
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    Default Cinco De mayo Regatta
    Hey folks,
    the Northern VA Model yacht club is hosting it annual Cinco De Mayo Event on Saturday May 3rd in Reston VA. While its more than a month away Doesn't hurt to start planning early..
    http://www.nvmyc.com/Northern_Virgin...NOR-SI-REG.pdf
    Marc
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  2. #2
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    Default Re: Cinco De mayo Regatta
    May 3 2014
    3rd Annual Cinco De Mayo RG65 Regatta
    Date May 3, 2014
    Northern VA Model Yacht Club
    Lake Anne
    Reston, VA
    Winds: 3-5 with gusts 8-10 SSW
    Course: windward with offset, leeward gate
    After 15 races with 2 throw outs
    Marc Smith 25 Ester65e Sloop
    Craig Huzway 30 Pakinto Swing
    Rob Suydam 33 Blue Splash Sloop
    Jim Kammel 45 Pakinto Sloop
    Scott Allen 68 Simmatara Sloop
    Mike Campbell 69 Skinny Swing
    Charlie Fawcett 76 Pakinto Sloop
    Rick Bray 93 Pakinto Swing
    Mike Russom 102 Pakinto Sloop
    After nearly 7 inches of rain earlier in the week, the clouds parted the sun came out and the wind blew as predicted. We had skippers coming from nearly 200 miles away to sail with us, with a couple skippers sailing their RG’s for the first time.
    The day started with the first 5 races providing four different winners, proving that this was not going to be a walk in the park, and that clean and consistent sailing would be needed. Susan Allen stopped by and dropped off Chipotle Burritos for lunch, which was eaten after seven races. With no throw-outs calculated the top 5 skippers, Marc, Craig, Rob, Jim, Mike C, were separated by 10 points. When the puffs happened, you had to ensure you were pointing the proper direction and maintain control to take advantage of the acceleration. Just about every boat broached, knocked down or showed the crowd her rudder at some point. Mike Campbell’s Skinny went bow down a few times and when one of the deck patches let go, he had to retire with unrepairable electrical issues. The only other mechanical problems were a broken rudder servo, and a broken mainsheet, both of which were fixed in short order.
    Sailing was generally clean, a few folks ventured OCS a bit early and had to come back, and the occasional mark was rubbed resulting in 360’s. Several port/starboard incidents occurred with only a couple minor entanglement and no major collisions or mishaps. Penalty turns were taken by those in the wrong with no disagreements.
    In the end, Marc’s consistent top three finishes and six wins proved too difficult to top, but Craig and Rob were chipping away at the lead and had a few more races been logged the results could easily swung in their direction.
    Green Chevrons were awarded to the top three skippers, accompanied by etched glass bottles filled with Mr. Cuervo’s finest nectar.
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  3. #3
    Join Date
    Mar 2014
    Location
    Santiago, Chile
    Posts
    100
    Blog Entries
    1
    Congrats Marc!!! Your win gives me some good motivation to tune my boat. This weekend I started building a ligther keel. Hull is watertight now. Putting water inside was my way to go anyway. I have to rebuild the interior and redesign the rig and I will be ready to go.
  4. #4
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,295
    Well done Marc, I'm pleased to discover that the first Esterel 65 in the water, is also the first to cut the line ! All is in the thumbs, of course !
    Little remark, a lower jib may produce better 'invisible' results....
  5. #5
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    Tarm,
    glad you got the moisture problem solved...
    Claudio,
    I did lower the jib to the deck...Yes thumbs are important, but...a fast hull helps... the Blue Splash and Pakinto are no slouches, and Mike's Skinny from brazil was knocking off good numbers (two wins) before his failure.
    The boat is still rigged, and I now need to record all the settings on the boat. Such that I can duplicate the performance
    At the end of this month I'll head down to Richmond for the region 3. so I'll be able to test the boat in different conditions.
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  6. #6
    Join Date
    Mar 2014
    Location
    Santiago, Chile
    Posts
    100
    Blog Entries
    1
    Marc: do you have detailed results from this event? I would like to take a look at them...
    Thomas Armstrong
  7. #7
    Join Date
    Aug 2003
    Location
    Minnesota USA
    Posts
    3,811
    Hi Marc - congrats again, and thank you for the write-up which included the regatta conditions. Always nice to get an idea of the weather conditions. Was everyone running full size "A" rigs?
  8. #8
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    Tom,
    what kind of details are you looking for?
    All A rigs. if the puffs held I would have considered switching to a B rig, but there was not enough consistency to warrant the change and to be honest I think only three of us had B rigs. I wasn't going to switch until someone else did
    Our sailing area is very protected. http://4.bp.blogspot.com/-9rcjAhteiO...n+the+lake.jpg so we don't have to worry about waves or chop, and as a result of the buildings we do get the occasional 0-3mph drifter. I think based on our location, we are able to carry the A rigs a bit higher than others...
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  9. #9
    Join Date
    Mar 2014
    Location
    Santiago, Chile
    Posts
    100
    Blog Entries
    1
    Quote Originally Posted by marcsmith View Post
    Tom,
    Results by individual heats.
  10. #10
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    I have not digitized those yet, I hope to have it up and done by weeks end..I need to do the takeoff from the hand written sheet to spreadsheet.
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
+ Reply to Thread
Similar Threads
  1. RG-65 Regatta
    By GPZY in forum Announcements
    Last Post: 11-20-2012, 04:14 PM
  2. 1st Annual Conco de Mayo RG65 Regatta
    By gwrench in forum General Discussion (RG65)
    Last Post: 05-06-2012, 08:34 PM
  3. Region 6 RG-65 Regatta
    Last Post: 10-19-2011, 11:56 PM
  4. Watseka Regatta
    By tbarjohn in forum Announcements
    Last Post: 04-11-2006, 02:02 AM
  5. AC Regatta
    By imported_chad in forum General Discussion
    Last Post: 03-28-2004, 04:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
