+ Reply to Thread
Page 11 of 19 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 183
Thread: 12mR scale 1:12
  1. #101
    Default Re: 12mR scale 1:12
    Hello again. I know this rig will be a bit much, but I wanted it to look scale. I'm going to build one more rig, B size to be able to sail in heavier breeze. I will bend the mast like the original. In the picture, there is no back stay.
  2. #102
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Much depends on the ballast you manage to fit in the keel.
    I do assume that the scale factor is 19.22m : 1.8m =10.67
    Displacement factor should be the cube of : 10.67x10.67x10.67 = 1214
    Australia Displacement was 21800kg, therefore the model weight should be 21800 /1214 = 17.95 kg
    How much of this weight is supposed to go into the lowest part of the Keel ?
    Answer not really required !
  3. #103
    the keel weight is 17.8 kg. The hull is probably 300 grams heavier due to the fact I built the hull as a plug to begin with.
    I will produce a mold in the fall. From the mold it will be easy to produce a hull at less than half the hull weight in the current model.
    The wings are lead and the boat feels very stiff when I test float the boat. I think I will be able to sail in winds up towards 4-5m/s.
    Lars
  4. #104
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Hi Lars,
    I didn't expect a keel so heavy.
  5. #105
    Continued work on the rig today. Also sprayed some more paint on the keel area. Almost done painting, and ready to wet sand and polish again.
    The weather is super nice today and I took the opportunity to be outside working on the rig.
    //Lars
ID:	16058Click image for larger version
ID:	16059Click image for larger version
ID:	16060Click image for larger version
  6. #106
    Worked on the sails last night. Got help from a buddy who is a sail maker.Click image for larger version
ID:	16140Click image for larger version
  7. #107
    Cut the mast curve today.
  8. #108
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Interesting and shape appears well done. The Jib for when ?
  9. #109
    I hope to finish the sails this weekend.
    Will work on the main tomorrow.
  10. #110
    Been working on the jib sheet system this weekend.
+ Reply to Thread
Similar Threads
  1. AC- scale 1:30
    By claudio in forum America's Cup Boats
    Last Post: 01-17-2010, 07:30 AM
  2. Scale Express 27
    By express27 in forum New Classes
    Last Post: 06-15-2009, 01:40 PM
  3. Scale Sailing
    By JayDee in forum Problems/Comments/Suggestions
    Last Post: 03-30-2009, 05:14 PM
  4. source for scale scale fitting
    By WindWarrior6682 in forum General Discussion
    Last Post: 07-06-2006, 06:19 PM
  5. Scale Sail
    By Matthew Lingley in forum New Classes
    Last Post: 05-01-2005, 06:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
