+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: AC 120 build in Poland
  1. #1
    Join Date
    Jul 2012
    Location
    Poland, Ketrzyn
    Posts
    70
    Default AC 120 build in Poland
    Hello everyone,
    At last I have started to build my AC 120 boat. Too bad it is late and I didn't get a chance to go to any regatta's but hopefully the boat will be ready for next year
    The boat I put on my workshop is ETNZ - 92. I am using Claudio D's plans that are free to download, so I hope he doesn't mind
    Now that I put the shadows on the construction board, it looks like the top edges of the last three shadows do not make the smooth line. The line is "broken". The middle shadow is about 2 mm lower. Is it the mistake, or is the way it supposed to be?
    with the help of the knowledge that is to be found on this forum and the advice of more experience colleagues I hope for succesful project.
    regards,
    Lukasz
ID:	13803Click image for larger version
  2. #2
    Join Date
    Aug 2003
    Location
    Minnesota USA
    Posts
    3,811
    Default Re: AC 120 build in Poland
    Maybe the gunwale line is part of the rear "step" as shown in this photo from another forum thread/post?
    Just guessing !
  3. #3
    Join Date
    Apr 2009
    Location
    Gulf Harbour, New Zealand
    Posts
    1,242
    Hi Lukasz,
    The shadow lines should follow the hull plan line (nice & smooth) here is the building board set-up for that ETNZ plan. Wishing you a good build, it is a great boat !!
Name:	Frame plan setup.jpg
    Cheers Alan
    You can only create, what you can imagine
  4. #4
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Quote Originally Posted by woody-77 View Post
    Hello everyone,
    regards,
    Lukasz
    Attachment 13803Attachment 13804
    Hi Lukasz,
    Sorry about that, let me check the shadows drawings again. I will come back soon
  5. #5
    Join Date
    Jul 2012
    Location
    Poland, Ketrzyn
    Posts
    70
    Hello,
    Thank you for the advice Alan and Dick, and Claudio there is nothing to be sorry about. Not everyone can make detailed plans like yours and the small mistake like this can happen to everyone. And first of all I suspect myself of misreading the drawings anyway. The alterations are underway and I am preparing for filling the plug with the foam (I do not like the idea of planking). Claudio let me know please once you check that shadow #11, I would like to double check I am going the right way.
    Lukasz
  6. #6
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Lukasz
    I did not find the error, nevertheless I cross check the basic frames with lateral and top views and retraced each single shadows.
    Please see attachment .zip file with PDF at scale 1:1
    It can be printed directly on A4 format . Check PDF printing scale factor for 100%
    Hope is OK now !
    lateral and top views:
    Attached Files Attached Files
  7. #7
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Hi Lukazs,
    watching closely the fist picture on the first post, I see that you have not removed the 3mm contour that is replaced by the wooden stripes.
    http://www.rcsailing.net/forum1/atta...3&d=1378321015
  8. #8
    Join Date
    Jul 2012
    Location
    Poland, Ketrzyn
    Posts
    70
    Hi Claudio,
    I assumed that this contour is to be replaced in order to install 3 mm balsa planking. Isn't it? Since I plan to do foam and tissue plug I simply left it be. Correct me if I am wrong.
    About the stern issue, it turned out that I misread the drawings. Simply the gap between the shadow 11 and the stern shadow is 14 mm too big.
    Thanks for the help,
    Lukasz K
  9. #9
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Hi Lukasz,
    Your assumption is correct.
    The outer contour of 3mm represent the 'final' dimension of the hull in case you wish to use wood stripes of 3mm thick.
    In this case the contour shall be cut away.
    Instead if you intend to insert blocs of foam, the outer dimension remain valid.
    CD
  10. #10
    Join Date
    Jul 2012
    Location
    Poland, Ketrzyn
    Posts
    70
    Hello friends,
    I hope everyone is well in this New Year ! past few months I have been lazy and didn't do nothing about my boat
    But lately I have finally prepared the plug for lamination
    I applied a polyurethane floor laquer over the automotive putty, and 6 layer wax barrier, so I am hoping for smooth separation. wish me luck.
    best wishes to all
    Lukasz
+ Reply to Thread
Similar Threads
  1. IACC 120 now extends to South America!!! (ITA-45 Build Log)
    By AWysiecki in forum America's Cup Boats
    Last Post: 11-28-2013, 04:14 AM
  2. New from Poland
    By bulipunk in forum Introductions
    Last Post: 11-20-2010, 01:20 AM
  3. hi from Poland :)
    By aXon in forum Introductions
    Last Post: 07-23-2010, 11:41 AM
  4. DUNNO - not controlled Footy - new project from Poland
    By iPD in forum General Discussion (Footy)
    Last Post: 05-10-2010, 02:50 PM
  5. Build Log first sailboat build - footy Razor
Posting Permissions
  • You may not post replies
  • You may not edit your posts
