+ Reply to Thread
Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 118
Thread: Build Log: IOM
  1. #11
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,533
    Default Re: Build Log: IOM
    taped up the deck and laid out 6oz, and 1oz glass...and also did some work on the hull plug.. had a few nicks that I needed to smooth out..
ID:	12442   Click image for larger version
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  2. #12
    Join Date
    Apr 2005
    Location
    Gold Coast Australia
    Posts
    125
    Hi Marc,
    You say your hull is a Bantock Vivid. Is this a new design? I can't find it on SAILSetc site.
    Tony
  3. #13
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,533
    tony...
    It is Grahams Hull. the vivid is a modified Fraktal. You are correct it is not posted on his site.
    it has less wetted surface, and a narrower transom...
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  4. #14
    Hi Marc,
    great work - does the overlap in the packing tape you use on the form not leave its mark on the epoxied form once removed ? do you use any wax on top of the packing tape ?
    Gilbert
    No race is finished till the finishing line is crossed !
    IOM Goth XP (Frank Russell Design), Frank RD sails, RMG winch
    A Class Sweet 9, Frank RD sails and RMG Winch
    Replica of Jet Service 2 1.7m in sailing condition
    Mni40 - Cobra sailed again in Nov 12. Great fun !
    Mini40 - Coyote in construction
    Dragon Force RG65 in sailing condition
    2m Trimaran project: first draft drawings done.
    www.IOMIRELAND.org
    www.ACLASSIRELAND.org
  5. #15
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,533
    it does leave a line the thickness of the tape. does not appear on the outside of the glass...
    remember I an not building a mold. i'm using the male plug to make a hull...
    after I pull a few more hulls off the plug, before its destroyed I will make a female mold.
    I have done it without wax, and it releases fine... but I have no other basis for comparison. Ie if waxing makes it easier or not...
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  6. #16
    thanks for your response Marc, In an earlier post there was a question about weight. Here is a newsletter from Seattle IOM club where you can find some handy information about weight. see pages related to the built of the SKA design. If it helps.
    Atb,
    G.
    www.IOMIRELAND.org
  7. #17
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,533
    thanks for the email link...
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  8. #18
    Hi Marc, any development on your IOM ?
    I'm gonna try your method of the packing tape to take a mold of the foredeck of an IOM before I cut it open so I can replace the piece I'll cut out - fingers crossed !!!
    www.IOMIRELAND.org
  9. #19
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,533
    no not much....i cut out the transom and the bow. I was not happy with the the way they tuned out. holidays, the wing project, and an classic motoryatch build have kept me pretty much everywhere but with the IOM...
    the other thing you could do would be to use saran wrap I have used it with some success... but it wrinkles so easily....
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  10. #20
    I did put an update on my post re the jib attachment point but it worked very well with the packing tape as you suggested. Brilliant...
    Oh and Merry Christmas to you
    Gilbert
    www.IOMIRELAND.org
+ Reply to Thread
Similar Threads
  1. Build Log: Albacore
    By marcsmith in forum General Discussion (RG65)
    Last Post: 02-05-2013, 09:10 PM
  2. cobra 5 build log
    By enrico74ec in forum General Discussion (RG65)
    Last Post: 08-16-2012, 09:12 AM
  3. Footy build log
    By qwerty2008 in forum General Discussion (Footy)
    Last Post: 01-14-2011, 03:18 PM
  4. Build Log first sailboat build - footy Razor
  5. FootyCAT Build Log
    By AndyT in forum General Discussion (Footy)
    Last Post: 05-23-2009, 08:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
