+ Reply to Thread
Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 118
Thread: Build Log: IOM
  1. #101
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    Default Re: Build Log: IOM
ID:	15927Click image for larger version
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  2. #102
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    getting close to paint. transom and fwd bulkhead left, and then shroud chain plates.
ID:	15933Click image for larger version
ID:	15934Click image for larger version
ID:	15935Click image for larger version
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  3. #103
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    Hull with servo mounts and bumper 655 grams
    Servos/rx. 100 grams
    Rudder 35 grams
    Battery 120 grams
    A rig 325
    Keel 2495
    Corrector weights 270
    This does not include paint.
    It will get splashed on Sunday
    .Click image for larger version
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  4. #104
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    it sailed....
    corrector weight are at the keel, and they are too far forward. transom was out of the water almost 1/2" so I'll swap corrector weights with the battery and see how that works out...
    but it took on water as well. so I need to find that. not much wind so i'm thinking bow, keel or rudder.
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  5. #105
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    found some pin holes, about half a dozen or so. looked to be a result of over zealous sanding rather than poor layup. Looks like I gotta slap some primer on it first before the next wet run.
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  6. #106
    Join Date
    Nov 2010
    Location
    Johannesburg
    Posts
    249
    Nicely done.
    Did I spot you using a keyboard stand for the line up of the keel and rudder?
  7. #107
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    Nap.
    It was a throw-away at work. so I re purposed it. Its also my painting stand. I put some seat belt webbing on it works fine. uit does'nt have the rubber feet on it so I put a small sandbag on the leg to make it a bit more stable when its holding a boat. just nice to be able to work on a boat thats at work bench height...
    its still has the sticker on it. its a ks7190 singlex
    with the webbing on it I only have two available height positions, but its very functional for what I'm using it for. knowing that these can be had for less than 30 bucks It would be a great addition to a work shop... and in place of the webbing you could just tie a couple small ropes, like paracord to make a soft sling to hold the hull so its not resting on the cross bars. Its just barely deep enough to hold the iom with the keel on it...
    go back and look at th epic in post 94 you can see the stand (lower right corner) also doubles as an end support for my building board. one end of the board is clamped to the work bench and the other end is supported by the keyboard stand...
    I have also found the the tall skinny trash cans work well for supporting boats for the purposes of painting rigging, ect... I keep hoping that at work one day I'll find a suitable vessel for creating a float tank...
    first coat of primer and sanding... a light coat today and more sanding prior to color...
ID:	15940Click image for larger version
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  8. #108
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    its orange....
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  9. #109
    Join Date
    Aug 2003
    Location
    Logan, UT
    Posts
    181
    Sweeeeeet
  10. #110
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,532
    so her is the b boat with a drawn on LWL. Its sitting about 1 cm down with the transom just barely touching this is with trim weigh full aft and battery behind the keel. so good for light air. but no good for heavy air.
    take a look at the bulb. it look slike it really far forward on the fin. I'm thinking if I cut in a new fin slot and move the fin forward about 4cm. it should help with the fore/aft trim. wich will allow me to get better trim with just the battery and to have the trim weight not so far aft.
    thoughts?
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
+ Reply to Thread
Similar Threads
  1. Build Log: Albacore
    By marcsmith in forum General Discussion (RG65)
    Last Post: 02-05-2013, 08:10 PM
  2. cobra 5 build log
    By enrico74ec in forum General Discussion (RG65)
    Last Post: 08-16-2012, 08:12 AM
  3. Footy build log
    By qwerty2008 in forum General Discussion (Footy)
    Last Post: 01-14-2011, 02:18 PM
  4. Build Log first sailboat build - footy Razor
    Last Post: 03-13-2010, 07:40 PM
  5. FootyCAT Build Log
    By AndyT in forum General Discussion (Footy)
    Last Post: 05-23-2009, 07:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
