+ Reply to Thread
Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 114
Thread: Build Log: IOM
  1. #1
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,517
    Default Build Log: IOM
    IOM 681
    Graham Bantrock designed hull "Vivid"
    What started out as 2 blocks of Dow Corning 4" thick insulation foam. Is now a male plug. Thanks to a good friend for his computer and CAD/CAM/CNC machine, he working on a goth plug.
    my plan is to do what I've done on the Albacore(bilge rat) 6,4,2 ounce glass
    I just finished a hull for a 1920's powerboat(Augusta) using the same glass method. and the bare hull prior to finish sanding/paint is 10.4 ounces... and its 38" long
    being that the iom hull is much skinnier and not nearly as much free board... getting the bare hull with no deck close to 225-250 grams should not be a challenge.
    need to order some more glass before I start glassing though...hate to run out...
ID:	12188   Click image for larger version
ID:	12189   Click image for larger version
ID:	12190   Click image for larger version
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  2. #2
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,517
    Default Re: Build Log: IOM
    had enough glass for Vivid Hull #1....
ID:	12196   Click image for larger version
ID:	12197   Click image for larger version
ID:	12198   Click image for larger version
ID:	12199   Click image for larger version
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  3. #3
    Join Date
    Jun 2008
    Location
    L.A.(Eagle Rock) California
    Posts
    56
    What would be an ideal weight for a bare IOM hull ?
  4. #4
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,517
    I've been seeing a complete hull with deck and fittings around 500 -800 grams... I figure if I can come in at 225-250 for the hull, adding the deck and fittings should put in the 500-600 gram range...
    old info, but data is data..
    http://www.anderswallin.net/wp-conte...et2003july.pdf
    I put in the transom and bow tonight. so I should have some pics and weights of the bare hull tomorrow..Fingers are still sticky...
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  5. #5
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,517
ID:	12204   Click image for larger version
ID:	12205   Click image for larger version
ID:	12206   Click image for larger version
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  6. #6
    Join Date
    Aug 2011
    Location
    Quebec, CANADA
    Posts
    108
    Good and fast work Marc. Thank you for taking the time to share this build with us.
    I am puzzled. How did you come up with a nice and smooth closed transom and bow hull from your opened ends hull? Maybe your pictures are just too low-res to understand your work. I imagine that you preformed the bow and cut the transom out of a plat f/g plate. But your joints seem so perfect!
    Sylvain
  7. #7
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,517
    Sylvan,
    I'll take some closeups this afternoon. it is not nearly as purty as you think... i used some painters tape to close up the ends from the outside and than laid up 3 layers of glass from the inside.. I then used some west 105/206 with some micro light filler 410 on the inside to as a fillet. I will need to mix some west with the low density filler 410 for the outside to fair the joints. the bow joint will be covered with a bumper. have not cut the bumper yet...
    in all honesty getting the hull shape is usually the hardest part, but having someone who has access to nice equipment has made life a bit easier and a lot cleaner. having to sand the foam is one of the bigger PITA's
    235 grams
    keel fin, keel bulb, keel trunk....the fun really begins...
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  8. #8
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,517
    bow and stern....see not real purty when you look close...the stern will fill and blend nicely. not sure about the bow...it may get cut out and redone...
ID:	12208   Click image for larger version
ID:	12209   Click image for larger version
ID:	12210   Click image for larger version
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  9. #9
    Join Date
    Apr 2011
    Location
    Maryland
    Posts
    113
    Looks like work has slowed a bit..
  10. #10
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,517
    unless you want pictures of sanding dust... : ) holidays have slowed me down a bit.
    I have 3 dinners in the next three days to prep for..
    I do have the deck plug ready to lay up. I was hoping to have another hull to lay up at the same time....but someone is slacking in that department...
    Maybe when you come over for the club meeting we can lay it up...
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
+ Reply to Thread
Similar Threads
  1. Build Log: Albacore
    By marcsmith in forum General Discussion (RG65)
    Last Post: 02-05-2013, 09:10 PM
  2. cobra 5 build log
    By enrico74ec in forum General Discussion (RG65)
    Last Post: 08-16-2012, 09:12 AM
  3. Footy build log
    By qwerty2008 in forum General Discussion (Footy)
    Last Post: 01-14-2011, 03:18 PM
  4. Build Log first sailboat build - footy Razor
  5. FootyCAT Build Log
    By AndyT in forum General Discussion (Footy)
    Last Post: 05-23-2009, 08:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
