+ Reply to Thread
Page 1 of 17 12311 ... LastLast
Results 1 to 10 of 170
Thread: Esterel footy
  1. #1
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Default Esterel footy
    A new Footy for Christmas !!!
ID:	12185   Click image for larger version
Name:	Rev1 - Rigs.jpg‎
  2. #2
    Join Date
    Mar 2008
    Location
    genova, Italy
    Posts
    216
    Default Re: Esterel footy
    well done !
    Flavio
  3. #3
    Join Date
    Nov 2004
    Location
    New Hampshire, USA
    Posts
    921
    Nicely done, Claudio.
    Two things you might double check:
    The rudder needs to have full motion used in racing while in the box...from your drawing, I think it would jam against the box in one direction. Moving it forward a bit would allow the needed clearance.
    The bowsprit on the conventional rig as drawn might keep the boat from being able to get completely in the box. The bowsprit can be outside the box, but the deck and cabin need to be below the top of the box. Mounting the bowsprit on top of the deck, while not as pretty, might solve the problem.
    Welcome to the Footy clan. Be careful, though....Footys can be addictive :-)
  4. #4
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Thank you Bill for the suggestions, I will introduce the mods !.
    True I'm not familiar with the Footy secrets !! , but my nephew ask me one for Christmas.....he din't specified the year !
  5. #5
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Hi Bill
    here the checks made.
    For the rudder no problems !
    While for the bowsprit I'm not sure if it is OK now !
    The red dotted lines represent the Box Rules !
  6. #6
    Join Date
    Nov 2007
    Location
    Basel, Switzerland
    Posts
    98
    Wow, not only a very professionally presented design but one which has been modified very very rapidly too. All the information I would require, and more, is here to see with little left to guesswork.
    Please would you let us know which tool(s) have been used here and how steep is the learning curve to be able to produce such good results?
    Phil
  7. #7
    Join Date
    Nov 2004
    Location
    New Hampshire, USA
    Posts
    921
    Looks good, Claudio.....should be fine now.
    Like Phil, I'm curious....I've seen your beautiful drawings here for some time....what tool are you using? I use Freeship and Hullform, but they don't produce drawings like yours.
  8. #8
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Fine Bill so is OK now ! good
    Phil and Bill, about drawings,
    I use since 1994 the Coreldraw ver.5 , It is a 2D graphic soft composed of various modules that can be selected the ones wanted.
    I use only the Drawing module. Very easy to learn. Actually not in commerce anymore but can be free downloaded from special web sites. Book can still be found in specialized libraries. like Amazon.com :
    http://www.amazon.fr/Mastering-Corel...2764902&sr=1-5
    https://www.google.fr/search?q=corel...ient=firefox-a
    Developed for Win3.1 is still running today with XP, for how long I do not knows. Just bought for 90€ a second hand restored PC with XP just in case.
    I don't like 3D soft in general, nevertheless I learned how to make simple wire-frame 3D drawings with the Rhino demonstration. Some sample at the beginning of Onetwotwo tread.
    That's it
    PS: Of course the Footy above is only one version, since I have another one of 305mm length and wide transom.
  9. #9
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    This is the finally elaborated Diagonal plan. It offer more displacement then needed therefore stays some place to add corrective ballast.
    Interesting features : LOA/LWL 325mm - Beam 109mm - Hull Draft 32mm - PC 0.574 - LCB -3.5%
    Canopy a little change.
    The master, instead of using the foam as already done, I will employ the "bread-butter" technique with plywood of 5mm.
    This will produce, once finished, a nice static model as well the form to make the female mold.
    I need to trace each single horizontal plan every 5mm.
    More drawing to come.
  10. #10
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    To note :
    5 times in one month for Saturday, Sunday and Monday!
+ Reply to Thread
Similar Threads
  1. 1.2.3. - "esterel"
    By claudio in forum New Classes
    Last Post: 11-05-2012, 06:56 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
