+ Reply to Thread
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: rigging ideas
  1. #1
    Join Date
    Mar 2009
    Location
    Hayward, Wisconsin
    Posts
    89
    Default rigging ideas
    After mucking about for the last three weeks trying to get sheeting lengths and jib/main angles correct for a new boat, it makes me think that perhaps it would be easier to use flat rectangular spars
    for the jib and main booms. Easier to drill multiple holes through a flat carbon spar than trying to figure out a simple way to secure on a 6mm round, and make it adjustable.
    Any thoughts? I have done allot of internet research on this subject, trying to find the most easy, simple way to make adjustments quickly,not many answers, What do you do?
    I have seen the rubber o-rings and wound wire thingies, but wonder if there is another lighter way to do it.
    Kurt
  2. #2
    Join Date
    Oct 2009
    Location
    Ontario Canada
    Posts
    64
    Default Re: rigging ideas
    Kurt...
    For my Jib, I use fuel line clamps from my hobby store. Cheap and light. Look at the Jib in this pic. It is not a '65 but is is a 6mm jib boom :-)
    Grav
  3. #3
    These work great. I just tie the line to them and clip them on.
    http://www.kitebuilder.com/catalog/i...ath/29_149_151
    1 Footy
    4 RG65s, 1 (perpetually) in planning
    2 Marbleheads
    1 J105
  4. #4
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,531
    i use fuel tuping cut into 1/8" section. mulch like the rubber oring. i deadman the sheet below decks and have all my adjustments on the booms... one hole directly above the fairlead. on the end of the sheet, when fully sheeted in with trim the fishing snap hook is almost at the fair lead.
    http://www.fishingtackleunlimited.co...DS-50-Z-P.html
    on the boom is a loop that is tied through the fuel tubing such that when passed through the hole in the boom the fishing snap hook attches to the loop. then I can slide the fuel line tube up or down the boom to fine tune the sheet angle. this what I do on my victoria, soling (only difference is wood spars) , and RG65. I have a similar setup on my EC12(aluminum spar), but I utilize a Z bent wire in place of the fuel line tube with holes drilled into flat side of the booms that the Z bend hooks to.
    Also keep in minds that once you get your settings nailed down. this is not an adjustment you have to continually adjust...
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  5. #5
    Join Date
    Mar 2009
    Location
    Hayward, Wisconsin
    Posts
    89
    These are all great ideas, I like the fuel line clamps have never heard of those before. plastic clips look interesting as well.
    Marc, I have a Vic as well and have thought about using some sort of elastic setup to dump the jib in a gust, but look I'm getting
    off my own topic now. As far as the RG class it seems to me that weight is imperative and simplicity of design, ease of adjustment
    are key. Everything else is in your thumbs. Always allot of good information here at RC Sailing.Net.
  6. #6
    Join Date
    Nov 2010
    Location
    Colorado
    Posts
    122
    I use lots of grommets from radio shack for boom adjustments. the variety pack is ~$2 and has a bunch of sizes. Once you find the place that they need to be permanent, you can glue them to the boom if needed. I use them from RG up to M sized boats.
    Jfisher
    Star 45 national champ 09,10 Star # 842
    Julie Ayers Winner 08
    10R national champ 07 10R #12
    RG-65 #577
    M #3718
  7. #7
    Join Date
    Mar 2009
    Location
    Hayward, Wisconsin
    Posts
    89
    I just ordered some carbon tubes, 6mm round and 5mm square. My idea is to use the round for the mast, with the shrouds attached at the front of the mast. and use the 5mm square for the booms.
    I can easily drill lots of holes in the square spars for sheet adjustments on jib, main, booms. On my Vic and my simpatico the shrouds are located on the side of the mast, my thought is to place
    them centrally at the front of the mast so there is less interference with the sail sheeting out in a reach or downwind. This would also let me locate the stays on the deck further forward, which
    could allow a better sail shape on the down wind legs.
    Any thoughts?
    Kurt
  8. #8
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,531
    Kurt, is your mast roll wrapped or pultruded. I have found the the pultuded carbon are not on ly "heavy" but also much more bendy than the roll wrapped tubes.
    one way to make attachment points on carbon tubes with out having to drill them is to wrap a fitting to the mast, much int he same way a fishing rod guide is wrapped to a pole. and then a light dab of CA will "lock it" in place. nice thing about CA one you star "unwrapping" the string it will break free such that if you need ot move it you can.
    I have done this with small cotter pins which had been bent to suit my needs. since they are folded in manufacture to create a circleular cross section, each side of the wire is a semi circle make it much easier to wrap it.
    not sure if the 3mm is going to make that much difference with sail shape on a run...
    on my vic mast, I drilled 4 holes for the shrouds and I terminated the shrouds at the aluminum mast head crane such that there are now stresses on the holes in the mast.
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  9. #9
    Join Date
    Aug 2003
    Location
    Minnesota USA
    Posts
    3,810
    "Sort of" on topic.......
    Was looking at some carbon tent pole replacements tonight at Wal-Mart. Under Coleman name. They have metal slip-fit ferrules, and I couldn't find a "for sure" size. As I recall, they are packed four rods per pack, 27 inches long each (2 tops, 2 bottoms) and "I THINK" 6 mm dia. (????) and look to be pultruded - which I am guessing, since the pop-up dome tents like bendy tent poles.
    I wouldn't use these on any hard-core race boats, but they might work where weight isn't critical. The package was under $10.00 (US) so might be of some interest/use.
    Just a thought and am passing on in case anyone might want to visit the sporting goods section to look. They were in the tent repair section - and of course it is almost end of season here in the upper mid-west for most fair-weather camping.
  10. #10
    Join Date
    Mar 2009
    Location
    Hayward, Wisconsin
    Posts
    89
    Dick, any idea is welcome, and you never know where things can be sourced from. I didn't realize when I ordered my carbon fiber material that it was being shipped from china.
    So I guess I'll have to weight for it and see how things weigh up. ARGH!
    Marc, I am just thinking that the sail would rotate better if the shrouds were attached at the front of the mast rather than the sides.
    Kurt
+ Reply to Thread
Similar Threads
  1. Keel Bulb ideas
    Last Post: 10-04-2008, 06:22 AM
  2. Ideas for Footy hatches
    By Nolan2 in forum General Discussion (Footy)
    Last Post: 01-08-2007, 05:31 PM
  3. Non-Racing Ideas
    By Dick Lemke in forum General Discussion
    Last Post: 09-11-2005, 02:39 PM
  4. ideas
    By cougar in forum The Local Pub
    Last Post: 08-07-2004, 01:38 PM
  5. goose neck for victoria ideas
    By express27 in forum New Boat Owners
    Last Post: 02-27-2004, 08:39 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
