+ Reply to Thread
Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 76
Thread: Ranger plans and pics
  1. #21
    Join Date
    Jul 2005
    Location
    Brooklyn, NY USA
    Posts
    524
    Default Re: Ranger plans and pics
    I have used West System 105 mixed with 410 Microlight to a paste-like consistency to fill the grain in Balsa. Apply along the grain and then remove as much of the filler as you can by scraping it off with an old credit card or similar diagonally to the grain direction. Don't build up any on the wood surface, only in the grain. When cured sand lightly and repeat if necessary. Then apply paint or spar varnish to seal the wood.
    You might also try the liquid grain fillers that are used in guitar building. I have used these on several instruments that I've built but I haven't used it on Balsa yet. I suspect that it would leave the Balsa more flexible than the epoxy system and might be easier to sand off. It probably won't matter too much if it is waterproof or not if you are going to paint the surface anyway.
  2. #22
    Join Date
    Sep 2010
    Location
    Daytona Beach, Florida, USA
    Posts
    35
    Thanks for the info. I used z poxy finishing resin blotted as much as possible and then sanded down to smoothness. Now I'm at the point where I just need to sand the bow block and give it a finished coat of paint. I'll provably do it camouflage blue so no other boat sees me coming ... lol I'll try to take some pics in a min.
    Thanks for the advice!
    Enrico
  3. #23
    Join Date
    Sep 2010
    Location
    Posts
    35
    Here's some pics of our progress so far
    Enjoy
    Enrico
ID:	7663   Click image for larger version
  4. #24
    Join Date
    Sep 2010
    Location
    Posts
    35
    Hi Guys,
    We managed to finish both and yet to finish making sails. We hope we can get them wet by Tuesday afternoon. We have made rig A for my Dad in Law's boat and I'm sporting my C rig from my Razor 3 just for the looks. Very nice boat. Cant wait to get it in the water.
    Enjoy
    Enrico
ID:	7667   Click image for larger version
ID:	7668   Click image for larger version
  5. #25
    Join Date
    Sep 2010
    Location
    Posts
    35
    Well, we had our first maiden of both rangers yesterday. Conditions where with steady 5-9 MPH winds. My dad in law boat was first to hit the water with the C rig. I came next after settling my sons Footy. O was using a 600 mm mast with high aspect ratio sail. Both boats tracked straight upwind and had no tendency to submarine down wind. My boat was a tad faster overall. In general both where fast boats. We tried running a few legs upwind. And also down wind and gave my son about 10 ft start. Halfway to the mark we would catch up and at the mark we would be about 4-5 ft ahead. My dad in la had a bit of water sipping in issues but in general the rangers where nimble to tack and turn and react to accelarate from a stand still. Both boats are equipped with hs81 for sail and t-50 for rudder. My ranger with a 6 channel park spektrum receiver and single cell 420 Maj liposuction weights in at 320 7 grams. In comparison my razor 3 weights 317.5 grams with out battery. Sorry forgot to take pictures in the excitement. We'll do more tests and have the razor to compare before the end of the week.
    Thanks Bill for such great design!
    Enrico
  6. #26
    Join Date
    Nov 2004
    Location
    New Hampshire, USA
    Posts
    926
    You had perfect conditions for your maiden voyages, Enrico...glad you like the boats.
    While you were sailing, we got 5 inches of snow here! Spring will come soon, though.
    I'd like to see a picture of your high-aspect rig, if you get a chance...people might be interested in an alternative from the rigs in the plans, and it sounds like yours worked fine.
  7. #27
    Join Date
    Sep 2010
    Location
    Posts
    35
    Hi Bill,
    I'll take some pictures tonight after work. The rig looks great with such a sleek boat. I think it was a coincidence it worked out good since I tried it on my razor 3 and it was iffy. I guess the higher aspect ratio goes well with the narrower hull. Please don't take my word on it, I am just supposing ... My theory behind it is that compared to to sailplane wings, higher aspect wings require higher speeds for the same lift of a low aspect wing. So my bogus conclusion was, The higher aspect ratio I can make it and the boat can handdle, the faster its going to be. The sail 312 from my razor in the previous pictures is a C rig high aspect sail. It works fabulous with the razor, makes it go fast but I works lousy on winds speeds lower than 10 -14 mph. The other reason I tried it was because I ran out of material making my dad in law's sails and I wanted to test the water desperately! LOL
    Not sure how to say this: It worked best with the sail with a bigger curvature than it being too tight. (sorry, not sure the terminology ) I guess its the down haul? anyway, It worked good also when the wind died down from barely blowing to 3 or 4 mph. I'm still going to make the A rig from your plans, I like it! Big! sure it will have a good advantage in very low wind conditions!
    Sorry, to much writting, is just too exciting!
    Enrico
  8. #28
    Join Date
    Feb 2010
    Location
    Bristol UK
    Posts
    41
    Hi Bill,
    Glad to see people ate taking to the ranger like a duck to water.
    I met up with another footy sailor over the weekend in derby, and we has some sailing competiins in complete drifting conditions.
    We both had very close to the same area, and the light weght ranger would just get up and go past the BUG in winds the bug would only just move in. Unfortunately rather too dark for photos, but good fun
    I also had a sail of my Ranger hull in the pavilion garden pond in Buxton. I had the BIG rig from my razor on it, and it handled i well. the wind was very light to start with, but picked up quite a bit.
    As you can see in the pic, it handled it well.
    Even in thet wind, the ranger only ever nodded its nose under (the shear lines mean the deck is almost parallel to the water for the first inch at that point, and so it tracked straight, and bobbed stright back up when the gust passed (all the while running very close to Hull speed given shape of waves)
    Scott
  9. #29
    Join Date
    Sep 2010
    Location
    Posts
    35
    Hi Bill,
    I gathered some measurements on the sail and rig.
    RIG:
    mast: 654 mm
    Boom: 228 mm
    Distance from main mast to pivot location: 68mm
    SAIL:
    General: luff: 618 mm
    foot: 205 mm
    The sail is divided into 3 sections.
    section 1:
    foot: 205 mm
    luff: 250 mm
    Section 2:
    foot: 155 mm
    Luff: 180 mm
    Section 3:
    foot: 105 mm
    Luff: 185 mm
    Head of sail is 33mm wide
    The angle of the main mast in relation to the pivot point falls directly perpendicular, that means, the top of the mast is aligned to the pivot point.
    Here are some pictures that may help illustrate. Please this has done by the TLAR method and a simple formula, if Bills sails have a XX% of ratio to the pivot point what percentage should I do mine. Please try it and let us know of any possible modifications, improvements, etc!
    Enrico
ID:	7675   Click image for larger version
ID:	7676   Click image for larger version
  10. #30
    Join Date
    Sep 2010
    Location
    Posts
    35
    Hi Bill and all,
    It is incredible how time flies when you're having a lot of fun!! The Footy Regatta sailed at Vero Beach, Fl, proved that I really need to hone up my skipper skills. So many mistakes, too many missed the mark and couple of 360.The important thing is that it was a lot of fum.
    Well, back on the ranger subject, We did get a chance to compare it to the rest of the boats. Mainly pool sharks 2 and 3 and some other sleek designs too, the Ranger was one of the skinniest in the block!! It took me a while to trim it out and start finding the sweet spot. On the way, I also had to verbally sail for my dad in law so many times I lost complete concentration on what I was doing. As for the Ranger, we started with the A rig and a constantly switching back and fourth between the A and B rigs was going on. At some point the A rig was nice going down wind but lacked somewhat forward speed. The B rig in general (my own explained on the previous post) lacked both up wind and down wind efficiency. I think I need to add 1.5 inches to the trailing edge to give it a little more "drive". The C rig I think i got it just about right! On my 7 th race I had a great start, I gained an advantage on the upwind leg of about 5 boat lengths; on the reach leg I really was able to pick up about a 50 ft distance between me and second place boat. On the down wind leg to the finish line, the spread between my ranger and the second place was about half way of the total distance to go. In few words, I bit the H2o out of everyone else! nice! good thing It only lasted for one race, but it was enough to prove that the Ranger has huge, and I mean HUGE potential to beat anyone anytime. Note: The c rig worked great due to the higher wind that started blowing at that moment for this particular race, subsequent races the wind died a little and I wasn't able to to get the same advantage (plus a lot of mistakes!!)
    All in all I must say that I'll probably have to build a second ranger just in case I wear out this first one! More experimenting with the sails is required but the theory about the high aspect did somehow work! (just be careful not to give it a tooo high aspect ratio)
    On the aspect ration issue, the B rig had a 0.3534 aspect ratio percent while the C rig had a 0.5 aprox ratio percent.
    Here are some pictures from the regatta!
    Enjoy
    Enrico
ID:	7711   Click image for larger version
ID:	7712   Click image for larger version
ID:	7713   Click image for larger version
ID:	7714   Click image for larger version
ID:	7716   Click image for larger version
ID:	7717   Click image for larger version
+ Reply to Thread
Similar Threads
  1. workbench pics...
    By marcsmith in forum General Discussion
    Last Post: 10-15-2010, 01:33 PM
  2. Footy Pics
    By IanHB in forum Gallery
    Last Post: 02-10-2008, 03:07 PM
  3. New footy and pics
    By John Storrow in forum General Discussion
    Last Post: 04-10-2006, 07:56 AM
  4. vsk3 pics!!
    By wismerhell in forum Sailing Simulators
    Last Post: 09-30-2005, 08:27 AM
  5. Electronics pics
    By nacra521499 in forum General Discussion
    Last Post: 10-09-2003, 10:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
