+ Reply to Thread
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Footy build log
  1. #1
    Default Footy build log
    This is VOYAGER my first RC sailboat so its not the best.
    I don't have a scale but it all ready sits on the water line and I don't have the receiver or battery in it yet.
    I currently had no hobbies so I started to build a footy razor.
    Here are some pics plz tell me what you think ty.
ID:	5158   Click image for larger version
ID:	5159   Click image for larger version
ID:	5160   Click image for larger version
ID:	5161   Click image for larger version
ID:	5163   Click image for larger version
ID:	5164   Click image for larger version
ID:	5165   Click image for larger version
ID:	5166   Click image for larger version
ID:	5168   Click image for larger version
ID:	5169   Click image for larger version
ID:	5170   Click image for larger version
ID:	5171   Click image for larger version
ID:	5173   Click image for larger version
ID:	5174   Click image for larger version
ID:	5175   Click image for larger version
ID:	5176   Click image for larger version
    Last edited by qwerty2008; 03-13-2010 at 11:35 PM. Reason: I forgot to put the name
  2. #2
    Default Re: Footy build log
    Sorry I forgot the older pics here they are.
ID:	5178   Click image for larger version
ID:	5179   Click image for larger version
ID:	5180   Click image for larger version
ID:	5181   Click image for larger version
ID:	5183   Click image for larger version
ID:	5184   Click image for larger version
ID:	5185   Click image for larger version
ID:	5186   Click image for larger version
ID:	5188   Click image for larger version
ID:	5189   Click image for larger version
ID:	5190   Click image for larger version
ID:	5191   Click image for larger version
ID:	5193   Click image for larger version
ID:	5194   Click image for larger version
ID:	5195   Click image for larger version
ID:	5196   Click image for larger version
ID:	5198   Click image for larger version
ID:	5199   Click image for larger version
ID:	5200   Click image for larger version
ID:	5201   Click image for larger version
ID:	5203   Click image for larger version
ID:	5204   Click image for larger version
ID:	5205   Click image for larger version
ID:	5206   Click image for larger version
ID:	5208   Click image for larger version
  3. #3
    Here are some pics of VOYAGER in my measurement box
ID:	5220   Click image for larger version
ID:	5221   Click image for larger version
ID:	5222   Click image for larger version
ID:	5223   Click image for larger version
  4. #4
    Here are some pics and a video I took of voyager in the water. It already sits at the bottom of the transom so its a bit heavy but its not going to be a racer so who cares.
ID:	5387   Click image for larger version
ID:	5388   Click image for larger version
ID:	5389   Click image for larger version
ID:	5390   Click image for larger version
ID:	5392   Click image for larger version
ID:	5393   Click image for larger version
ID:	5394   Click image for larger version
ID:	5395   Click image for larger version
ID:	5397   Click image for larger version
ID:	5398   Click image for larger version
ID:	5399   Click image for larger version
ID:	5400   Click image for larger version
ID:	5402   Click image for larger version
  5. #5
    i ordered the tx/rx system it should be here in 3 to 4 days
  6. #6
    Welcome to 'the hobby'!
    Looks good. Interesting to see a winch in a footy.
    The biggest difference in weight can be made in the batteries.
    Consider a small cell phone battery.
    Rusty
    George Little: Maybe we should go home.
    Mr. Little: Why?
    George Little: I'm not wearing my lucky underwear.
    Mr. Little: You don't have lucky underwear.
    George Little: Well, maybe we should get some, and then come back for another race.
  7. #7
    How would i wire that ?
    thank you
  8. #8
    all the cell phone batteries i could find were 3.6 or 3.7 volts my setup takes 4.8 to 6.0 volts
  9. #9
    Most AM and FM receivers and servos will run well on 3.6volts.
    The light weight aircraft guys used to run on 3 cell nicads for years.
    A fully charged LiPo or LiIon cell is over 4 volts and discharges down to about 3volts before it needs to be shut off to prevent damage.
    I suggested a small cell phone battery because they are readily available, as to are the chargers, cheap (surplus), and have a built in protection circuit to shut them down before fully discharged.
    On a small footy with a balanced rig in moderate conditions, you should budget on 100mAHr drain, so a small battery should last most of the day.
    They do not appreciably self-discharge, have no memory effect on recharge, and are incredibly light.
    The one I have in my DLG glider weighs 3.6gm and will power the FM receiver and two analogue servos for an hour and a half!
    The LiIon in my footy with a McRig I got from a surplus electronics store for $1 and is 19gms (heavy) metal encapsulated, delivers 450mAHr. It has no protection circuitry so I just have to remember to charge it every second time I go sailing and its ok. They are supposed to have a shelf life, so be conservative with older stock.
    The lower voltage may slow the servos slightly and give a little less torque, so size the sail servo accordingly. A McRig does not need much anyway. The lower voltage also increases the battery time because of lower current draw too. Unlikely to be any range problems from the receiver.
    Attached is a photo of the footy power wiring. The loom is attached to a socket for the receiver scrounged from a common old computer lead, and a switch jack (switched power socket) sourced from an electronics supplies outlet and takes a common charger power plug. The cell is charged and monitored through this plug. Monitoring of the cell voltage is done with a 50 ohm resistor loaded volt meter that mimics a loaded cell. This may be prudent if using a small 'racing' pack on a windy day. The circuit is isolated by inserting the plug. A short rubber plug or tape covers the socket when sailing. When making one you may need a multi meter to verify the function of the socket lands - one side of the switch goes to the charger circuit and the other to the receiver. They are available ready wired from DLG glider outlets eg, http://olgol.com/TabooGT/form.html.
    If your system by some quirk requires more voltage, then this cheap circuit will boost to 5volts: http://www.hobbycity.com/hobbycity/s...ooster_for_BEC
    If you run an old (heavy!) AM receiver, many of these have a BEC circuit which will allow you to run 2 LiPo batteries in series (2S pack), the circuit will reduce the voltage to 5v for the receiver and servos by wasting it as heat!
ID:	5844   Click image for larger version
    Rusty
    Mr. Little: Why?
  10. #10
    I have a nicad double/triple A battery charger that charges four at a time that's what I was planing to charge it with and run it off four double A batteries.
    this boat is not going to be a racer mainly because it is my first and I did not do very well but also because I live in California U.S.A. and there are no rc sailing groups near me.
+ Reply to Thread
Similar Threads
  2. My first Footy build...
    By rickeboy in forum General Discussion (Footy)
    Last Post: 09-24-2009, 05:22 AM
  3. Victor Models V-12 Footy Build
    By bozinator in forum General Discussion (Footy)
    Last Post: 06-24-2009, 11:16 AM
  4. My First Footy Build
    By Sunshine in forum General Discussion (Footy)
    Last Post: 05-06-2009, 11:32 AM
  5. How To Build A Razor Footy
    By ROADTOAD in forum General Discussion (Footy)
    Last Post: 02-27-2008, 03:06 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
