+ Reply to Thread
Results 1 to 3 of 3
Thread: AC- scale 1:30
  1. #1
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Default AC- scale 1:30
    I told myself, while I was building a couple of RG65, that perhaps a litle sister of the AC120, largely discussed in another tread, would be of interest to those that like boat shorter of 100cm.
    The attached PDF drawings are for an AC 130 that sizes only 80cm being on scale 1 :30 and weight less than 1.5 kg.
    This AC130 is supposed to fill-in the place between the RG 65 and IOM/US One Meter.
    Only one Hull is drawn onto which any America Cup decorations could be applied.
    Sail Plan of max. 3500cm² and Appendix drawings will follow.
    Any comments ?
    PS, I have developped an AC120, starting from 4 kg instead of 4.5 kg, therefore it is "out of rules", but being lighter should present interesting performances - noting that it is possible, within the actual Rules, to be build lighter than 4.5kg, but a ballast is required to comply with the 4.5kg requested by the Rules.
    Any interest ?
    Attached Files Attached Files
  2. #2
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    Default Re: AC- scale 1:30
    The maximum Sail Plan surface is of 3500 cm².
    The maximum Mast lenght from the deck is 1175 mm
    The fore Stay is hooked to the mast at 80% of the Main lenght
    This the overall view :
    The Nominal Sail Plan is of 3200 cm²
  3. #3
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,281
    the boat Plan including centering data . minimum CLR - CV lead 8.3%
    CE at 32mm from back face of mast.
+ Reply to Thread
Similar Threads
  1. Scale Sailing
    By JayDee in forum Gallery
    Last Post: 02-26-2011, 06:48 PM
  2. Scale Express 27
    By express27 in forum New Classes
    Last Post: 06-15-2009, 12:40 PM
  3. Scale Sailing
    By JayDee in forum Problems/Comments/Suggestions
    Last Post: 03-30-2009, 04:14 PM
  4. source for scale scale fitting
    By WindWarrior6682 in forum General Discussion
    Last Post: 07-06-2006, 05:19 PM
  5. Scale Sail
    By Matthew Lingley in forum New Classes
    Last Post: 05-01-2005, 05:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
