+ Reply to Thread
Page 1 of 11
1 2 3 ... LastLast
Results 1 to 10 of 110
Thread: FUXIA 65 / Polystirene Story
  1. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    FUXIA 65 / Polystyrene Story
    This time, more than before, I let the images to talk about the extruded polystyrene foam usage to make an easy hull model shape. This tecnique is not new, but is worth to recall back before the End of 2009. The Main advantage is : CHEAP and FAST !
    HAPPY NEW YEAR To ALL MODELERS !
    Attached Thumbnails Click image for larger version
ID:	4559   Click image for larger version
ID:	4560   Click image for larger version
ID:	4561   Click image for larger version
  2. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    Re: FUXIA 65 / Polystirene Story
    next pics :
ID:	4564   Click image for larger version
ID:	4565   Click image for larger version
ID:	4566   Click image for larger version
  3. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    3rd sending
ID:	4568   Click image for larger version
ID:	4569   Click image for larger version
ID:	4570   Click image for larger version
  4. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    4th sending
ID:	4572   Click image for larger version
ID:	4573   Click image for larger version
ID:	4574   Click image for larger version
  5. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    5th sending
ID:	4576   Click image for larger version
ID:	4577   Click image for larger version
ID:	4578   Click image for larger version
  6. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    6th sending
    including a flash about the Bulb construction using lead sheet of 1mm thickness
ID:	4580   Click image for larger version
ID:	4581   Click image for larger version
ID:	4582   Click image for larger version
  7. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    AS a conclusion this is the FUXIA 65 design.
    The hull shape is an heritage from the AC33 concept
    Best 2010 !
    claudio
  8. Join Date
    Aug 2003
    Location
    Minnesota USA
    Posts
    2,922
    Claudio -
    Well Done !
    I have tried to explain the process many, many times - and never thought of providing a step-by-step with photos. This really explains how easy it is, and how a person can produce one, or many hulls from the same shape. I originally tried the idea back in eary 1990's and made a plug for a C&C41 from which a hull was produced. From there I have used it for building many of my multihulls - from the current 65M (65 cm) up to my 1.2 F-48/Mini40. My 1 Meter multihull (I only have the remaining prototype ) also produced some light weight hulls. The packaging tape for hull release has been a long standing suggestion as well, since it leaves only a slight ridge where tape overlaps that needs to be sanded out - but since it appears only on theinside of the glass hull, it can be ignored.
    Regardless - again, a well done explanation on a method for fast, easy method to try a new idea or design, or build a fleet of boats for family or local friends.
    Thank you so much for posting, and a Healthy and Happy New Year to you and family. I know the guys down under are in 2010 already, but we are still waiting. [grin]
    Dick Lemke
    Minnesota, USA
    AMYA member
    "The F-48 Multihull Class - Remarkable for its rarity - unmatched in originality"
  9. Re: FUXIA 65 / Polystirene Story
    This method looks like a great way to quickly test out new designs without having to build plugs or use wood hulls. Thanks Claudio!
    Eric
    Eric Rosenbaum
  10. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    Quote Originally Posted by Dick Lemke View Post
    Claudio -
    Well Done !
    Many thanks Dick,
    Sorry if I was usurpating this section, since I have seen others treads on RG65.
    Happy New Years to You and to All the Modelers. Another 5h15min for us in Nice.
+ Reply to Thread
Similar Threads
  1. story about local R/C sailling on Marco Island FL
    By WindWarrior6682 in forum General Discussion
    Last Post: 12-05-2005, 01:41 PM
  2. The Hula Full Story
    By booster in forum The Local Pub
    Last Post: 09-08-2004, 01:03 AM
  3. Sticker story
    By John Storrow in forum General Discussion
    Last Post: 03-22-2004, 08:40 PM
  4. Snatched from the jaws of Ice: a story
    Last Post: 01-09-2004, 10:09 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
