+ Reply to Thread
Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 59
Thread: 2-metre trimaran build
  1. #11
    Default Re: 2-metre trimaran build
    Happy New Year to all -- the main hull plans are to come soon
  2. #12
    Join Date
    Sep 2008
    Location
    United Kingdom
    Posts
    187
    Hi Siri, just wondering how the 2metre Trimaran is coming along - looking forward to seeing the full set of plans.
    Ray
  3. #13
  4. #14
    Join Date
    Sep 2008
    Location
    United Kingdom
    Posts
    187
    It's nothing really, just a little gift....
    Seriously, what package are you using to draw the lines, if we contact via private message would you have .dwg or .dxf format files you would be prepared to share? I could be interested in building from your lines.
    Ray
  5. #15
    Join Date
    Sep 2008
    Location
    United Kingdom
    Posts
    187
    Hi Siri, how's the 2metre tri build going?
    Ray
  6. #16
    Hi Ray,
    as soon as my other unfinished projects (Marblehead, IOM and RG65) are off the building board the 2m will be started.
  7. #17
    Join Date
    Jan 2006
    Location
    Canada
    Posts
    439
    But now you ar going to have to change the plan and build a wing sail!!!!
    John Ball
    CRYA #895
    IOM CAN 307 V8
  8. #18
    Hi John,
    the BP5 does not have a wing so no changes needed to the plans,
    if I'm going to build an BMWOracle in the future I will need go for a wing
  9. #19
    Finally I have cut the shadows for main hull and floats. Next step will be to set up the building boards and attach the shadows to the boards.
    main hull templates
    float hull templates
  10. #20
    Join Date
    Aug 2003
    Location
    Minnesota USA
    Posts
    3,811
    Hi Siri -
    will this one start life as a foam plug like previous ones - or do you plan to strip build it?
    We finally had a break in the weather today and I measured snow in back yard as up just above my knees. Will be some time before it all melts. Hope it is a slow melt to avoid major flooding. Spring can't be too far behind.
    Regards
+ Reply to Thread
Similar Threads
  2. 2 metre catamaran build
    By nautibuoy in forum General Discussions (MultiHull/MultiOne)
    Last Post: 11-21-2009, 12:15 PM
  3. trimaran plans?
    By Albertaclipper in forum General Discussion
    Last Post: 07-26-2009, 05:49 AM
  4. HELP,want to buy cat or trimaran yacht !!
    By aussie_sailor in forum General Discussion
    Last Post: 02-25-2009, 04:16 PM
  5. RC Trimaran Hydrofoil
    By keving in forum General Discussions (MultiHull/MultiOne)
    Last Post: 06-24-2004, 09:03 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
