+ Reply to Thread
Page 1 of 11
1 2 3 ... LastLast
Results 1 to 10 of 101
Thread: Delta rig
  1. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    Delta rig
    Is any one interested to this type of project ?
    There is no name yet to define this type of Rig, Gary Hoyt called Delta Rig, Phil Bolger Staysail, other called simply Cat. The problem is that the mast is positioned at the end of the Hull close to the Stern.
    Only one single sail acting as a big jib. No main and no mast disturbing the air flows to the main !
    Little history :
    The first boat with this type of rig was constructed in 1992 by Nicolas Montgomery in Florida. Was an expensive prototype because of the technology limitations, it was difficult to build a mast capable to maintain a very stiff forestay. The boat structure presented some difficulties to. In spite of that proved to be very fast and easy to sail.
    In the Phil Bolger book “Boat with an Open Mind” retrace the full story.
    Later in 1984 the CorSair 24 was developed. Was also easy to sail and very fast under strong winds.
    In 1994, Gary Hoyt wrote an article on Sailing World dedicate to the Cyclone of Mr. Simmons from California.
    So far I knows one of the most active Yards designing Delta Rigs is :
    http://www.runningtideyachts.com/monohull/ of Brian Eiland.
    More about various project : http://www.boatdesign.net/forums/boa...ig-1999-3.html
    Some pictures here below of real boat using the Delta Rig configuration :
    In 2003 I was attracted by the Staysail design proposed by Ph. Bolger in his book mentioned above, and I decided to develop a sailing model called CD-CAT based upon a simple class M hull. The results obtained were very good, very fast model, no nose down observed, fast reaction and very good accelerations. One defect observed, the jib is behaving as a wing and as such is sensitive to the wind incidence, outside certain limits the stalling condition occurs. The range for better performances is reduced to 5°-6°. Not easy to control when the boat is 150 meters far away. Good training is needed.
    Attached Thumbnails Click image for larger version
ID:	4009   Click image for larger version
ID:	4010   Click image for larger version
ID:	4011   Click image for larger version
ID:	4012   Click image for larger version
  2. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    Re: Delta rig
    my first project made in 2003 was the CD-CAT . At that time I tested a couple of sails materials.
    Some pictures here with a Blue nylon cloths generally used for kite.
    The general idea was to use the same sail surface of a Class M to manufacture the Jib. The surface was 7200 cm²
    The hull construction limited to the use of balsa sheets of 3mm and than covered with a couple of 80g/m² glass/epoxy.
    Most important point was to decide the mast Tllt in order to postion the sail CE against the CLR .
ID:	4014   Click image for larger version
ID:	4015   Click image for larger version
ID:	4016   Click image for larger version
ID:	4017   Click image for larger version
ID:	4019   Click image for larger version
  3. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    Re: Delta rig
    Some weeks later a new material was used for the sail and the jib was attached to a swing boom.
    This solution proved to be good when running because the CE was maintained close to the boat.
    Was very good until the boom started to bend and finally one hour later broken. I managed to make a new boom, but never tested also beacause suddently called up to design a new Class M : the Studio3 the last of a design serie.
    Today I wish to come back to this design using a spare hull of my CD65 project an RG65 Class.
    I will continue this tread only if some one manifest some interest and after the ETNZ IACC 120 will shows up a completed boat ready to sail.
ID:	4021   Click image for larger version
ID:	4022   Click image for larger version
ID:	4023   Click image for larger version
ID:	4024   Click image for larger version
ID:	4026   Click image for larger version
ID:	4027   Click image for larger version
  4. Join Date
    Sep 2008
    Location
    United Kingdom
    Posts
    186
    Re: Delta rig
    Claudio, thanks for starting this post, count me in as interested.
    I like to experiment and would like to learn more from your experiences with this rig. I notice that in your drawings you sgow a bipod mast - what if the bases of the bipod legs were in the hulls of a catamaran - just thinking out loud.
    Ray
  5. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    Re: Delta rig
    Hi Ray,
    I think it exist already, try the Brian Eiland site ...
    Ciao
  6. Join Date
    Apr 2009
    Location
    Heidelberg, Germany
    Posts
    235
    Re: Delta rig
    Hi Claudio,
    I have the mould of my ETNZ AC 120 sitting in my workshop (3 mm balsa) and I have already put 2 layers of 80 gsm FBG over the hull and stripped out the shadows with the idea of using it as the basis for wingsail experiment later.
    This project sounds more interesting & challenging, so I too am very interested in trying this concept, once I have finished my AC 120 build.
    In the mean time I will study the concept further in preperation for you to lead the way.
    Cheers Alan
  7. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    Re: Delta rig
    Great ! Alan,
    first I would like to respect the excellent work you are doing for the ETNZ, therefore before deviating the attention to other subjects, I let you and others to finish up before continuing in this new project.
    Tanks for the interest expressed, I appreciate
  8. Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    395
    Re: Delta rig
    lets go smaller. what about on a footy.. could the jib provide vertical lift IE to help keep the footy from buring its nose on the down wind runs?
    Maybe I'll work on my 507 thats not getting much sea time right now...
    a "wishbone" mast out of small carbon tubes to a forestay /pivot point...
    you'd only have one sail to "tune"
    time to go to the hobby store for some carbon....
    Marc
    6 Bits S1M 1981
    LoLA Victoria 81
    Bad Habit Odom 1981
    2 Bits v-12 1981
    Spliff 507 1981
    Microyacht Express
    EC12 2081
  9. Join Date
    Apr 2005
    Location
    Nice - France
    Posts
    949
    Re: Delta rig
    Quote Originally Posted by marcsmith View Post
    YES Marc,
    because the wind resultant force is orthogonal to the stay, or at least is what i suppose.
    Pratically I observed the real test performances on my old design.
  10. Re: Delta rig
    It looks like being able to change the mast angle allows you to move the CE instead of guessing and making more holes in the deck.
    Sail honest.
    Rock & Roll.
+ Reply to Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
