+ Reply to Thread
Results 1 to 8 of 8
Thread: workbench pics...
  1. #1
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,533
    Default workbench pics...
    Hey folks,
    got some new tools yesterday....
    table top belt/disc sancer, Drill press, Scroll saw, and a 48" Lathe
    this on top of my compound miter saw, and Table saw.
    I have a small shop in the basement 1.5" formica topped with 1/4" glass overlay. nice for doing small work and misc odds and ends..
    Problem... when I do any sanding small cutting (dremel, ect) the entire house ends up spelling like wood shop. I don't see the problem....Wife does...
    So...With the addition of these tools I am contemplating setting up a more permanent solution in the 2 car garage...
    basically turning the front of the garage in a work shop with enough space to get the cars in.
    Wondering if any one had any pics of their "shops" such that I could get some ideas working around in the grey matter thats resting atop my shoulders...
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  2. #2
    Join Date
    Jan 2006
    Location
    Canada
    Posts
    439
    Default Re: workbench pics...
    Hi Mark,
    You might take a look at sawdust collection vacuum systems for the basement shop.
    Moving into the garage, you may still get the smells and track dust into the house (don't ask!), and the damp may cause the tools to rust more than in the basement environment.
    John
    John Ball
    CRYA #895
    IOM CAN 307 V8
  3. #3
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,533
    It's an insulated garage And Ive never had any problems with any of my handheld tools rusting...
    the basement room is 20x20 and it shares space with the laundry area. Which is probably another reason the wife isn't appreciative of my hobby some times
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  4. #4
    Join Date
    Jul 2008
    Location
    Chile
    Posts
    117
    I am glad my wife is fully comprehensive and I have a nice workshop with enought space. Of course form time to time she complains about traces odf fiberglass in my cloth spreading all around the house...
    In other cases, or you change the worshop location, or change the wife!!!
    Marcsmith. You should organize your workshop so all the tools that pruduces dust be at one side or corner , so it is easier to clean. Also, put a piece of scrap carpet at the exit of the basement, so you can clean up your shoes bottom...and if you go up with a rose for her from time to time, you wife will not complain as much.
    Good luck.
    Tato Lazo
  5. #5
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,533
    been with this wife since 97 it would be too expensive to change now...
    and 75% of the basement is finished....
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  6. #6
    Join Date
    Aug 2008
    Location
    Bradford, PA
    Posts
    26
    A few years ago WOOD Magazine had an article called Idea Shop 2. It showed how to have all the tools for major woodworking in a 2 car garage. It is an excellent read and is still on their website. http://www.woodmagazine.com/ideas/wo...e/idea-shop-2/
    For small modeling alone it is overkill but you can pick and choose from their ideas. actually , they have done at least 5 different concept shops to perk the imagination.
    I don't think I kept the issue because I have been blessed with a very understanding wife who said "no problem" to adding on a dedicated shop as an addition to our house. Even so, I used several of their ideas: reference center, tool mover, and the mobile cabinets . they have been very useful.
    I second the recommendation of a dust collector. The Grizzly medium system allows high volume low pressure flow that will handle an amazing amount of sawdust and fiberglass grindings at a low price. I switched it and my major saws to 220 volts and have beau coup power. I can grind thick fiberglass warship hulls in front of a 4" hose and watch the air stream entrain all the particles making a dust mask optional. It is a must have.
    Start by looking at the G1028Z.
    Nate
  7. #7
    Join Date
    Nov 2006
    Location
    Northern VA
    Posts
    1,533
    Well I figured I'd post some pics. before/after. I ended up adding 24 feet of countertop space and 14 feet of cabinets above and below. 30 amp dedicated 240v cicuit with 120v power strips along the wall. the circuit can power a welder or plug my fathers 42' rv to household power.
    did all the work myself.
    nice gaps in the cabinets to set a rigged boat up.
    now I just need to keep it clean...
ID:	4605   Click image for larger version
ID:	4606   Click image for larger version
ID:	4607   Click image for larger version
ID:	4608   Click image for larger version
ID:	4610   Click image for larger version
    Marc
    S1M 1981
    Victoria 81
    RG65 181
    IOM 81, 681, 881
  8. #8
    Looks like a good, usable workspace. Well done!
    RD
+ Reply to Thread
Similar Threads
  1. Footy Pics
    By IanHB in forum Gallery
    Last Post: 02-10-2008, 03:07 PM
  2. New footy and pics
    By John Storrow in forum General Discussion
    Last Post: 04-10-2006, 07:56 AM
  3. vsk3 pics!!
    By wismerhell in forum Sailing Simulators
    Last Post: 09-30-2005, 08:27 AM
  4. Awesome pics
    By yachtie2k4 in forum The Local Pub
    Last Post: 10-21-2004, 10:00 AM
  5. Electronics pics
    By nacra521499 in forum General Discussion
    Last Post: 10-09-2003, 10:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
