+ Reply to Thread
Page 7 of 65 FirstFirst ... 567891757 ... LastLast
Results 61 to 70 of 645
Thread: ETNZ IACC120 Dual build thread
  1. #61
    Join Date
    Jan 2006
    Location
    Canada
    Posts
    439
    Default Re: ETNZ IACC120 Dual build thread
    Hi Goose,
    Western red cedar is very common out here in BC (we grow it). You should be able to find it at a good lumber yard or at a place that makes fencing. In Ontario, you may find eastern white cedar. That should work too. Check your yellow pages under LUMBER or FENCING
    The best grade is clear cedar, but if not available, regular fencing grade can be used. It comes in various sizes, eg lathing, and 1by3, 1by4 and in 6, 8 and 10 ft lengths.
    Pick over the stack looking for edges free from bark and as few knots as possible. Look for outer planks as they are less dense than heart wood. Warped planks are not much of an issue as you will be splitting it into narrow planks and they will bend quite easily.
    On the saw, I use a narrow kerf planer blade for very clean cuts.
    John
    John Ball
    CRYA #895
    IOM CAN 307 V8
  2. #62
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Hi Goose,
    I discussed on the phone with Metivier Son and he confirmed that is sending often materials to Canada and this tends to confirm that there some difficulties to find various sorts of wood, others then the mentioned above, but as well generally employed by us modelers.
    Again this is the adress and site : http://metivier-modelisme.com/
    just in case "bois" means "wood".
    Metivier was telling me that the dispatch costs are around 22/25Ä and shipping time aroud 15 days to reach destination.
    Some time is faster. It happen to me to buy very often servo's material at : http://www.servocity.com/ - I never got problems.
    My supplier for : resin, glass/carbon cloths, carbon tubes, etc is : http://www.polyplancomposites.com/
    Also them can supply to abroad.
  3. #63
    Join Date
    Jun 2009
    Location
    Ottawa, Canada
    Posts
    104
    Hi John...
    Thanks a lot for that. I'm off to another local lumber supplier after work tonight and hopefully pick something up.
    Goose
    "Oh yeah, Kiwi's can fly..."
    http://www.goosesworld.com
  4. #64
    Join Date
    Jun 2009
    Location
    Ottawa, Canada
    Posts
    104
    Hi Claudio...
    Thanks again. I'm not ignoring your suggestion and the Metivier site is excellent... I'm simply making a point
    If todays mission is unsuccessful, I will order from that site but I'm getting close.
    Cheers!
    Goose
  5. #65
    Join Date
    Apr 2009
    Location
    Gulf Harbour, New Zealand
    Posts
    1,242
    Hi All,
    Heaps of rain here last couple of days with high humidity found this evening the paper templates are lifting off the shadows (spray adhesive) so thought before I lose the centre-line "if" paper templates fall off.
    Decided to glue-in the first frame support strips, here I used 7 x 3 mm Pine as thought it would be more stronger/stable than balsa in these humid conditions if they continue, donít worry Claudio I will be using balsa for the hull planking.
    Started with the side strips first and will do the keel strip last, reason
    ; so I can tap the shadows onto the centre-line below lay the keel strip later, the last check before planking. Also leave I will also glue the all 3 support strips onto number S0 last of all.
    Goose check that you bevel these S0 strips correctly, itís a tight fit.
    Tomorrow will do the gunnel support strips, then the final keel strip & then bevel the shadows ready for when the balsa to arrive on Friday.
    How did you go with your wood supplier today Goose ? hope to don't have to resort to Pine, bloody hard stuf to sand mate.
    Cheers K1
ID:	3503   Click image for larger version
ID:	3504   Click image for larger version
ID:	3505   Click image for larger version
ID:	3506   Click image for larger version
  6. #66
    Join Date
    Jun 2009
    Location
    Ottawa, Canada
    Posts
    104
    Gidday K1...
    Looks good mate, thanks for the warning about shadow 0.
    I'm interested to know what to do with the s10 end of the chine strip.
    No joy on the cedar, last chance for Canada tonight after work or plan B is to order it from France via Claudio's connection.
    Keep it up mate.
    Goose
    PS: What wood did you use for your shadows?
  7. #67
    Hello!
    I would want post some images of a new Fly Emirates New Zealand (Claudio project) in construction here in Roma by Alessandro Strappaghetti.
    Sails made by Luca 71-5, accessories by TD model (also the keel):
ID:	3508   Click image for larger version
ID:	3509   Click image for larger version
ID:	3510   Click image for larger version
  8. #68
    Join Date
    Apr 2005
    Location
    Toulouse (Fra)
    Posts
    3,301
    Goose and K1,
    you can glue a block of balsa between Frame 0 and and the Bow tip and stopping the planking at frame 0.
    The block is then shaped by sanding.
  9. #69
    Join Date
    Jun 2009
    Location
    Ottawa, Canada
    Posts
    104
    Hi Matthias...
    Great! Thanks for posting those pictures and thank Alessandro for us.
    Hi Claudio, will do... thanks.
    Goose
  10. #70
    Join Date
    Apr 2009
    Location
    Posts
    1,242
    Hiya Goose,
    I will cut the hull frame (side) support strip off at S09 as the keel strips and gunnels support strips go through to S12.
    Thanks Claudio about the solid balsa replacing the bow plate, I will do also.
    Matthias thanks for pics on Alex's new boat also ... just new carbon hull or is it change in design from his previous ETNZ ?
    Cheers K1
+ Reply to Thread
Similar Threads
  2. Ghost Train, texas style build thread
    By Mahoo in forum General Discussions (MultiHull/MultiOne)
    Last Post: 02-28-2009, 02:56 PM
  3. TP52 Thread
    By Millrtme in forum General Discussion
    Last Post: 02-26-2008, 10:57 PM
  4. FM Dual Conversion 'conversion' questions
    By andy25 in forum General Discussion
    Last Post: 09-25-2005, 04:17 PM
  5. A NEW THREAD MAYBE?
    By cougar in forum The Local Pub
    Last Post: 04-23-2004, 03:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
