+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Beta- Footy Design Plan Review
  1. #1
    Join Date
    Jun 2006
    Location
    Ohio, USA
    Posts
    119
    Blog Entries
    2
    Default Beta- Footy Design Plan Review
    Below Links need some repair from last update!!
    I am posting a link to the beta of a new review forum for hull plans and designs. I will hopefully be able to better intergrate this into my site.
    I encourage you to give it a try and let me know what changes need to be made or if you had issues.
    http://www.rcsailing.net/forum1/revi...wcat.php/cat/5
    Here is a direct link to upload your plans:
    http://www.rcsailing.net/forum1/revi...duct.php?cat=5
  2. #2
    Default
    Just Footies, or will you collect other classes and boats like static or scale ships?
    Sail honest.
    Rock music.
  3. #3
    Join Date
    Jul 2003
    Location
    Masterton, New Zealand
    Posts
    778
    Default
    Chad, I am only a little bit confused.
    What is the purpose of this thread?
    Is it as a depository for FOOTY plans?
    Sorry mate I am just a little thick, your advise is requested.
    Add Lightness !
    MICRO MAGIC NZL 01 "TAHI"
    IOM V5 NZL99
    Canterbury J NZL 196
    RG65 in the build
    Four foot six vintage, launching soon
    10 R Phoenix NZL 20
  4. #4
    Default
    Chad has a whole section for just plans ( the best idea I've ever seen!) It doesn't seem to be complete yet, so we'll need to wait for the go-ahaed before contributing anything.
    You may want follow the link and create a bookmark for the new section.
    Sail honest.
    Rock music.
  5. #5
    Join Date
    Jun 2006
    Location
    Ohio, USA
    Posts
    119
    Blog Entries
    2
    Default
    Tomohawk: The link above is just for the Footys. Depending on the success I will most likely open it up for other plans and models.
    IanHB: Pretty much an area for Footy plans where they can be entered and rated along with reviewed.
    I will need to know what fields are important to collect that would be common for all the plans. (ie dimensions, sail area, developer and even builders)
  6. #6
    Default
    Do you think we should set up guidlines on what information goes with a set of plans, like a materials list, building instructions, etc? I hope people will contribute their own tips for building a boat.
    Sail honest.
    Rock music.
  7. #7
    Default
    Great! Would you lease let us know when it's activated?
    Is there anything special we need to know to make things work out? files sizes, file types, etc.?
    thx
    Sail honest.
    Rock music.
  8. #8
    Join Date
    Jul 2003
    Location
    Posts
    778
    Default
    I have posted my free plan for Flatfoot.
    Add Lightness !
    IOM V5 NZL99
    RG65 in the build
    10 R Phoenix NZL 20
  9. #9
    Join Date
    May 2008
    Location
    Summers - Lake Fenton, MI Winters: Sebring, FL
    Posts
    342
    Default Re: Beta- Footy Design Plan Review
    I just posted a review for the Flat Foot as follows:
    "Only recommend if it is simple to build and sailed for non-racing.
    This is not really a plan as it does not show all the detail for building a completed boat. Need a lot more details including mast, keel and rudder placement and internal layout. If this is to be a helpful forum, a minimum set of requirements to post a boat should be established including expected performance (A --F) for racing. An "A" rating for top performing design vs. "F" for lowest performing."
    I am not coming down on Flat Foot as he is the first to submit a plan and requirements were not clearly stated. I applaud him for that. Thank you Flat Foot. Having one place to see various design suggestions vs. searching a lot of verbage is a good idea. I believe all of us do creative original things when we build a boat and I am thinking that I will submit one or two from my build.
    This could be a good section if we could get the authors to submit plans to a set of requirements as suggested above. Having just completed my first Footy, a gold colored Razor named "Gold Foot" (aka 007), I know the questions the beginner will have and all the wasted time it takes to figure out the details and end up with a boat that does not sail well.
    Maybe what is needed is a build section where data from all over the internet and various forums is consolidated into categories. For example, I would like see sections such as the following:
    Working with Balsa Wood
    Working with Adhesives (Epoxy, CA Glue, Fillers, Microballons, etc)
    Making Sails
    Boat Finishing for Light Weight, but Smooth and Glossy.
    Building the Rigging (Carbon Fiber, Lines, Fastners, etc)
    Electrical Considerations
    Building Custom Battery Packs
    For each area, require links to vendors to make parts easy to find and buy. Anyone want to help put some structure to this so it is useful.
    Let's make this a useful forum and continue fleet growth.
    Best Regards, FastFrank
    www.tanglewoodmyc.com
  10. #10
    Join Date
    Nov 2004
    Location
    New Hampshire, USA
    Posts
    881
    While it's certainly true, ffastffrank, that beginning builders want a lot more info than we often supply with our plans here, please recognize that producing detailed plans is an awful lot of work.
    I prefer building and sailing to drawing plans...I suspect Ian is the same way! While I have always tried to share info I thought could be helpful to other Footy builders, there's really no incentive for me to spend the many hours needed to develop detailed plans that I don't need and won't use myself. Even going so far as to convert my Freeship plans to .pdf format for publication (like Razor and Cobra) takes quite a bit of time.
    So I'm happy to provide people with the files I use for building, but I encourage builders to study pictures, read about design and building techniques, and get a bit creative when building one of my "plans." That's how I've learned, and that's all part of the fun of Footys.
    Your point is well-taken, though...so I think, from now on, I'll publish my stuff as "hull plans" so noone will be mislead.
    Bill H
+ Reply to Thread
Similar Threads
  1. Flatfoot. A quick build, free, Footy plan.
    By IanHB in forum General Discussion (Footy)
    Last Post: 03-12-2007, 09:42 PM
  2. Chris Dicks Footy Design Award
    By Angus - DECEASED in forum General Discussion (Footy)
    Last Post: 01-05-2007, 09:43 PM
  3. Footy Rig Gooseneck Design
    By TomoHawk in forum General Discussion (Footy)
    Last Post: 08-02-2006, 11:54 PM
  4. The Brits have a Footy design contest!!
    By mudhenk27 in forum General Discussion (Footy)
    Last Post: 10-15-2005, 08:22 AM
  5. Moderator's Review - Multihulls
    By Dick Lemke in forum The Local Pub
    Last Post: 05-08-2004, 07:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
